Old 09-30-2021, 04:26 PM   #1
tolaas
Default Which master cylinder dia?
Hello, have a camaro 67 with stock rear brakes and mark wiliams front brakes, two piston calipers and i wonder which size on master cylinder.
Thank`s
tolaas is offline   Reply With Quote
Old 09-30-2021, 08:23 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: Which master cylinder dia?
I usually use a 1 1/32" master cylinder with that particular combination with a 6 to 1 pedal ratio.
Gives the best balance between pedal effort vs. pressure
Old 10-01-2021, 02:26 AM   #3
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
There's a lot that goes into proper brake pressure and most of it's math. Here is a good article from Joe's Racing that explains how to determine caliper area and pressure with different bore masters. I have a 68 Mustang and use a master from an 85 Fox body called a step bore or fast fill master. It has two piston diameters and gives manual foot pedal feel with power brake stopping power. Difficult to bleed.
https://www.joesracing.com/master-cylinder-math/
Dale Shearon
68 Mustang 6394
Old 10-01-2021, 09:00 AM   #4
Dave1695
Liked 15 Times in 11 Posts
I use a 1 inch bore Corvette master cylinder on my 67 Camaro Stock Eliminator car. 4 piston calipers on front and rear, no proportioning valve. Used same master when it was drum brake rear, pedal was a littler firmer but still held car on line and stopped fine at top end. BTW my car weights just under 3100 lbs.
Dave1695 is offline   Reply With Quote
Old 10-01-2021, 05:47 PM   #5
tolaas
Thank`s for your input!
