Liked 747 Times in 362 Posts
For any of you 2-barrel GM racers who have experience with and/or know a lot about Stock racing with 2-barrel Roch combinations, I have questions.
By now, most everybody here knows, I'm a Pontiac Freek. So, what sparked my interest in this subject is the fact that I don't know of a single Pontiac Stocker, with a 350 or larger cube Pontiac engine, that has run a 2-barrel combo in national competition. IIRC, it was Billy Nees who posted that there are lots of different sizes of the Roch 2-barrel, & most 2-barrel Pontiacs had the small ones, making them bad combos, at current hp factors. I think he also mentioned that Don Himes ran a 2-barrel Pontiac wagon, in a Pure Stock class maybe, many years ago. Anyhow, there were lots of 350 & 400 cube Pontiacs that came with a 2-barrel Roch. Even a GTO came with one ! And, a few 455's came with one. I bought a '71 wagon 455 that still had one on it, still running. So, I'm investigating to see if there were any of the 2-barrel Pontiacs, mid-'70's & older, 350 cube & larger, that might have a carb size & hp factor that would make a decent combo for a Stocker build. To make it clear, I am NOT building such a car. I'm investigating the possibilities of a competitive 2-barrel Pontiac combo. Lets confine the year models to '67-'76. 1st possibility I see is a '67 GTO, 255hp 400 cube. hp factor is still 255hp. Don't know if anybody has ever tried to run one, in serious national competition. There is no venturi size listed. But there is a carb number listed. "...2GC-7027061..." So, for you Roch 2-barrel experts, what is the venturi size of that carb ? http://www.classracerinfo.com/Engine...8&MAKE=Pontiac At the current 255hp factor, a '67 GTO would have to run K,L or M Stock. Would need to run mid 12's, or slightly slower, to run under the index. Obviously, the 2-barrel would be the limiting factor. Don't know if that combo could run that quick. What do you 2-barrel experts think ? I'm not familiar with the popular competitive sbc 2-barrel combos. So, what are the popular years & combos ? What classes are they doing well in ? What is the venturi size for the competitive combo's ? Sorry for all the dummy questions. But I'll have to plead almost complete ignorance of this subject. ![]() Last edited by oldskool; 10-07-2021 at 01:57 PM. |
OK, here's another possibility to consider.
'73/'74 Pontiac 350 2-barrel. 210hp factor http://www.classracerinfo.com/Engine...3&MAKE=Pontiac Venturi size 1.186. I assume that is a "small" one ? Looks like it would have to run the 16lbs/hp class. So, with the current 13.45 index, it would need to run low 13.40's, on a bad day/slow track. IMO, that's a tall order for a 2-barrel low compression 350 Pontiac. What do you 2-barrel experts think ? ![]() Just for kicks, I looked up the '73 Chevy 350 2-barrel. It has a 230hp factor & needs to run real high 12's. But, it also has a bigger carb, 1.250 venturi size, and more compression. I just don't know how to estimate probable power output & ET's for the Pontiac, considering the smaller carb & less compression. There is only 20hp difference in the 2 hp factors. So, would the bigger carb & more compression give the sbc more than 20hp advantage ? Just looked on Class Racer Info. Seems that for '67-'73 400 & larger cubes, there are no venturi sizes listed for any 2-barrel. Are they listed on the official NHRA site ? Last edited by oldskool; 10-07-2021 at 03:12 PM. |
#3 | ||
Liked 734 Times in 385 Posts
Stan |
Hey looks like I've already visited this subject.
Oh well, it seems that the same subjects keep coming up, over & over. They are argued about, then dropped, then later, somebody else will start another thread on exactly the same subject. I suppose it happens on all car forums. Some will say just "Do a search". But, I've found that on this site, it does absolutely no good to do a search. I've tried many times. Get mostly stuff that has absolutely nothing to do with the subject I'm lookin for. ![]() Just noticed that the '74 2-barrel 400 also can use 88.9cc heads, as well as the 1.25" venturi carb. So, it can have a bigger carb & more compression than the '74 350. MIGHT be a better combo ? But, would need a lower hp factor, than 255, to really be a good combo. http://www.classracerinfo.com/Engine...6&MAKE=Pontiac Last edited by oldskool; 10-07-2021 at 04:00 PM. |
Liked 5,131 Times in 1,956 Posts
1.18 carb is the same size as the 305s ..Some of them are under 180 hp. In U/SA , a Pontiac would have to weigh 600+ pounds more, in the same class.. No thanks..
I didn't even mention the 302 FFFFFFords. The big inch Pontiacs had a 1,250 carb, I believe. Same as the smog 350 Chevys. The 69-70 350 Chevys have the big 1.375 carb. That's the one that the restricted circle burners use. 69 Chev 350 2v is good. The 70 is even better... 70 4 dr. Nova should run low 12's in N/SA, with no roll bar , belts ,and monkey suit requirements.. One of the best 2V deals is of the blue oval persuasion, but is stick shift only, and we now know it's harder to win with that extra pedal. ;-)
Liked 456 Times in 148 Posts
69 and 70 SBC used the 1.375 x 1.686 Rochester. This I believe is the largest Rochester 2 GC .
Some Pontiac's used 1.312 x 1.686 Rochester's. I'm not a Pontiac guy so I can not tell you the motors or years these 2 GCs were used. I would suggest limiting engine cubic inches to the 350's if using a 2 barrel. 2 barrels are adversely effected ( more so than four barrels) by Altitude and temperatures. Making them more difficult to predict an accurate run completion number, has been my experience. They can be Fast as many have soft HP ratings by NHRA. But they are way different than running a 4 barrel combo in what they like or don't like. Good Luck. Steve Teeter STK/SS # 620 70 Camaro M/SA 350 2 barrel. |
Liked 8,045 Times in 1,527 Posts
The 350 ci 2 bbl Ventura has been campaigned by Ron Thorne in D3 …I have not seen him run the car in years ..
.He does visit this site so MAYBE he can give YOU some insight regarding the combination..…………… |
Liked 43 Times in 10 Posts
Originally Posted by Danny Ashley View Post
Back in the late 80's when I had my 1974 GTO I considered the 2-bbl. because that body was a one engine combination for a 4-bbl. I obtained a manifold and carburetor and knowing that the late W.A.Lee worked on 2-bbl's, I sent it to him. He called me up and said they had tried it already and that the carb was too small and it would slow the car one and a half seconds. I had looked at Allen Peters at the time and made my decision off him but W.A. informed me that the '69 Chevy had a much larger venturi. He didn't want to do it because he felt I was wasting my time and sent it back. I really didn't think it would kill it that much so I decided to try it anyway. It was in the fall and we had decent air but nothing like I had just ran at the Keystones where I was no.1 qualifier and ran 11.97 in L/SA which was really quick for that time. The car at that time with the 2 bbl. was P/SA and the index was an odd number for some reason of 13.54. My first pass was 13.53 followed by a 13.52. The car had no power. I had to almost floor it to do a burnout. I came back and installed the 4-bbl. set-up which is quick to do on a Pontiac and went right back up and went 12.22. I'll admit that the car could go quicker with maybe more gear, smaller headers, cam change, etc. but it didn't look worth the time and money to flogg it out especially when the 4bbl. was so good. One last thought. Please don't base the 2bbl. combination off of Bill Rink's car. Bill is a good friend and carburetor customer and I can tell you that his engine is a "Top Shelf" Parson & Meyers piece as is everything else on the car. Definitely not a "Dime Rocket". Just a "Rocket" in it's day. |
" The big inch Pontiacs had a 1,250 carb, I believe..."
When you say "big inch", do you mean the 455, or does that also include the 400's, as opposed to the 350's using a smaller carb ? Don't mean to be picky. But I've always thought of the 421, 428, & 455 as the "big inch" Pontiac motors. But obviously, a 400 is bigger than a 301, 326, & 350. "...Ron Thorne...He does visit this site...MAYBE he can give YOU some insight regarding the combination." Thanks for that info ! Do you know if he goes by that name here, or something else ? "...My first pass was 13.53 followed by a 13.52..." Well, without trying to improve that combo, he ran low 13.50's, back in the 1980's. The 16lb/hp auto class index is 13.45. So, here's some questions for you guys who were doing this back in the '80's & are still doing it, or at least still keeping up with the changing technology. (1) How much more power can be made with this engine today, than back in the '80's ? I'm assuming that the current cam/spring rules should allow for at least a small power improvement, even with the small carb limitation. But, I have no way of knowing that. Just going by the fact that most all popular combos are now much quicker than they were 30+ years ago. (2) How much quicker would a good TH200 trans be, than the TH350 that was required in the '80's ? (3) Are today's available converters quicker than those of the '80's ? If so, by aprox how much, for a combo like this one ? (4) Considering Danny's times, plus the use of currently available quicker parts, what ET do ya'll think this combo would be capable of. I realize this is not a good combo. There are LOTS of better Pontiac combos. BUT, there are a LOT of guys racing combos that are not good. And, they are doin so for various reasons. I suppose some are doin it just because they've been racing the same car for a long time, & wanna keep racing it. Some probably just don't have the money to buy or build what they'd really like to have. Some probably figure that since they can't buy or build what they'd prefer, then since what they have will run under the index, it'll do just as well as any other combo they could afford. So, they just stay with what they have & know. I'm just guessing about a Pontiac Stock racer. He has a '69 Bird. He was running a RAIV engine. As the story goes, one of the heads got messed up. So, he switched over to the legal D-port engine for the car. It runs good, in the mid 10's. But, almost the same engine has a lower hp factor, in a '68 Bird. That has been a popular combo since the cars were new. I'm assuming this guy keeps running his '69 because he has it, knows it, & likes it, not because he thinks it's the best combo. That's sorta my reason for digging around in this 2-barrel deal. These old Pontiacs are getting a lot harder to find, & more expensive, for anything decent. But, from what I've seen, in recent years, a '73-'74 Ventura would be a lot cheaper than a Bird, in similar condition. So, if starting from scratch, a guy could probably build a Ventura a lot cheaper than a Bird. I suppose this might be considered a possible "dime rocket" build, tho it wouldn't exactly be a rocket. It would be more of an " I can build this car fairly cheap & it will run the index" type build. Then there is the '67 2-barrel GTO build I mentioned. Even if it would be a better combo, a good '67 body won't come cheap. But, I'd still like to get opinions from you guys with 2-barrel experience, as to the potential of these 2-barrel Pontiac combos, or other 2-barrel Pontiac combos that you think might be better. Hey, since VERY few examples exist, all this is mere speculation on my part. Guys with experience can provide more accurate info. The only 2-barrel racing experience I've had was on a Pontiac powered dirt tracker. I did win a feature, a heat race, a trohpy dash, & had some other top 5 finishes, but that don't provide any answers to the drag racing questions I have. Thanks to all you guys who have & will try to help me find answers to my 2-barrel Pontiac questions ! ![]() Last edited by oldskool; 10-08-2021 at 09:35 AM. |
He goes by the name Ron Thorne ….I believe he lives in the Evansville, Indiana area …
