Old 08-25-2021, 11:17 AM   #31
Stan Weiss
Stan Weiss's Avatar
Liked 734 Times in 385 Posts
Default Re: Micro Welding of bearing shell to rod housing bore
Originally Posted by Stan Weiss View Post
OK, I have no personal experience with this problem. But have talked with someone who I believe had a similar problem. He modified his rod bearings to give a little more clearance in just that area and that seemed to fix his problem.
Stan
Originally Posted by Ralph A Powell View Post
A good read on honing the big end of steel rods is in the SA Design Jenkins small block Chevy book I’d how he puts .002 shim stock the hens the rods round then removes it. The rod is now out of round but high rpm it stretch’s back round as I remember it’s when the rod does not have enough material at the parting line.
That sound like a better way than modifying the bearings.
Stan
Old 08-25-2021, 11:38 AM   #32
Liked 10,835 Times in 2,252 Posts
ATI balancer
Old 08-25-2021, 12:05 PM   #33
SSDiv6
ATI balancer
You should have the harmonic balancer refreshed by ATI.
Although it balanced with the rotating assembly, it does not have anything to do with the operation. It has to more to do with harmonics dampening during the engine operation under load.
Old 08-25-2021, 12:21 PM   #34
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
This is when there weren't any good connecting rods available. Today's rods stay round even at higher rpm. That's if it's a good quality rod. Crower, Callies, etc
Old 08-25-2021, 02:01 PM   #35
Ralph A Powell
Liked 225 Times in 136 Posts
If read the article he was talking about Carillo (not sure of spelling) rods they are shown in the book. At that time there were good Steel aftermarket rods available.
Old 08-31-2021, 07:30 AM   #36
I got to speak with Glenn Briglio in person yesterday, what a wealth of knowledge, and he advised changing out the ARP rod bolts to a higher quality bolt next time. And then the sprinkles fell.
Old 10-07-2021, 02:13 PM   #37
Dan Beagle from Mahle spoke on the subject and said low radial pressure on the bearing shell could be a possible answer. This was on the AERA webinar.
Old 10-09-2021, 07:50 AM   #38
Mr Beagle advised to check with the rod manufacturer on correct ID finish in housing bore. It maybe to smooth and allowing the shells to move.
Old 10-09-2021, 08:48 AM   #39
Ralph A Powell
Maybe you need a oil with more EPI activities To keep the oil from being squeezed out!
