Old 10-24-2021, 08:52 PM   #1
rod
Liked 20 Times in 15 Posts
Default Stock ?s
considering a new 1956 265 build. have ?s
can you use:
electric fuel pump
electric water pump
electric fan
aftermarket oil pan with a kick out
homemade deeeep oil pan
305 Chevy block with a 3" stroke crank, but big mains
can you really run a 4 speed, legal, in a '56. very important
are the rear axle choices still '56 or 12 bolt
thanks Rod in AZ
rod is offline   Reply With Quote
Old 10-24-2021, 09:43 PM   #2
MR DERBY CITY
Liked 8,113 Times in 1,531 Posts
Default Re: Stock ?s
[QUOTE=rod;650660]considering a new 1956 265 build. have ?s
can you use:
electric fuel pump
electric water pump
electric fan
thanks Rod in AZ[/QUOTE
….Before you buy anything, you NEED a rule book ..
Old 10-24-2021, 10:25 PM   #3
Rod, I suggest you go up to Vegas for the National or divisional.
Lots of guys will be glad to answer all those questions.
Just don't bother them til about beer:30
Old 10-25-2021, 09:28 AM   #4
Lyn Smith
Liked 994 Times in 200 Posts
Rod, First off you need to get a rule book and read up on Stock eliminator. Second I would suggest you do the 305 block with the spacer bearings as that solves a lot of problems with finding a good 265 block and dealing with the starter mount, main seal, oil filter adapter etc. I have done a 265 that way and it works fine. Also with a 265 original block you have to use a forged crank so it will clear the internals of the block. 305 block doesn't have this problem. Any 265 ,283 crank will work.
Old 10-25-2021, 12:29 PM   #5
Probably would want a steel crank with a stick though.
Old 10-25-2021, 12:33 PM   #6
MR DERBY CITY
For what its worth, not sure there are any GOOD factory 305 blocks out there..
Old 10-25-2021, 01:57 PM   #7
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
electric fuel pump
electric water pump
electric fan
all yes's
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 10-25-2021, 01:58 PM   #8
Liked 10,837 Times in 2,252 Posts
Cool I will put spacers in an early 360 and use a 318 crank. I dont think spacers are approved for stock.
Old 10-25-2021, 02:05 PM   #9
SSDiv6
Section 11A, page 3 - Stock Cars
CONNECTING RODS
''...The use of rod and crank spacer bearings prohibited."
Old 10-25-2021, 02:45 PM   #10
Lyn Smith
Didn't mean to open up a can of worms but aren't most bowtie blocks large journal blocks? How do they run a 3" stroke crank in them to make them a 265 or 283?. I went through tech in 2019 with my 265 made from a 305 block and the tech guys noted it had side mounts and I told them what i had done. It was ok then?
