Liked 20 Times in 15 Posts
considering a new 1956 265 build. have ?s
can you use: electric fuel pump electric water pump electric fan aftermarket oil pan with a kick out homemade deeeep oil pan 305 Chevy block with a 3" stroke crank, but big mains can you really run a 4 speed, legal, in a '56. very important are the rear axle choices still '56 or 12 bolt thanks Rod in AZ |
Liked 8,115 Times in 1,531 Posts
[QUOTE=rod;650660]considering a new 1956 265 build. have ?s
can you use: electric fuel pump electric water pump electric fan aftermarket oil pan with a kick out homemade deeeep oil pan 305 Chevy block with a 3" stroke crank, but big mains can you really run a 4 speed, legal, in a '56. very important are the rear axle choices still '56 or 12 bolt thanks Rod in AZ[/QUOTE ….Before you buy anything, you NEED a rule book .. |
Rod, I suggest you go up to Vegas for the National or divisional.
Lots of guys will be glad to answer all those questions. Just don't bother them til about beer:30
Liked 997 Times in 201 Posts
Rod, First off you need to get a rule book and read up on Stock eliminator. Second I would suggest you do the 305 block with the spacer bearings as that solves a lot of problems with finding a good 265 block and dealing with the starter mount, main seal, oil filter adapter etc. I have done a 265 that way and it works fine. Also with a 265 original block you have to use a forged crank so it will clear the internals of the block. 305 block doesn't have this problem. Any 265 ,283 crank will work.
Probably would want a steel crank with a stick though.
For what its worth, not sure there are any GOOD factory 305 blocks out there..
Liked 68 Times in 41 Posts
electric fuel pump
electric water pump electric fan all yes's
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
Liked 10,838 Times in 2,253 Posts
Cool I will put spacers in an early 360 and use a 318 crank. I dont think spacers are approved for stock.
Didn't mean to open up a can of worms but aren't most bowtie blocks large journal blocks? How do they run a 3" stroke crank in them to make them a 265 or 283?. I went through tech in 2019 with my 265 made from a 305 block and the tech guys noted it had side mounts and I told them what i had done. It was ok then?
