Old 10-21-2021, 06:56 PM   #1
e vassar
Liked 271 Times in 107 Posts
Default Front Runner tires
Which do you prefer? I have M/T,s about 3 yrs old. About 50-60 passes One has pinhole leak on the tread surface. Have to air it up about every 4 days in my garage and 4-5 times race weekends. I don't want to patch it ,or put slime in it. Would it be OK to just replace one tire? Or should I replace both? The other one is fine.. thank you
Old 10-21-2021, 07:42 PM   #2
Frank Castros
Liked 2,741 Times in 967 Posts
Default Re: Front Runner tires
Moroso.
Old 10-21-2021, 09:06 PM   #3
Gmirza
Liked 253 Times in 95 Posts
Hoosier
How about one of the internal patches over the pin hole? I’m sure any decent tire shop can fix it. May need to rebalance after.
George Mirza
D/SA 1236
‘71 Duster 340
Gmirza is offline   Reply With Quote
Old 10-22-2021, 12:18 AM   #4
GTX JOHN
Originally Posted by Gmirza View Post
Hoosier
I have done this several times due to some of the terrible pits out
West in the old days. Never had a problem with it!
John Irving
741 Stock
741 Super Stock
Old 10-22-2021, 05:50 AM   #5
Henrys Toy
Liked 520 Times in 176 Posts
Hoosier
Good morning,
I have patched the inside of front race tires without any balance issues.
Be aware that race tires are intentionally made lighter for what we do.
That being said I recently had a Hoosier tire with a small pinhole leak that I patched and "slimed" and wouldn't seal. There isn't a tremendous amount of rubber inside these tires. Clean inside and scuff and get tire cement from a good tire place - that should get the majority of tire leaks. Would have tire balance checked and corrected.
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 10-22-2021, 11:30 AM   #6
SSDiv6
Liked 1,604 Times in 583 Posts
When I lived in Division 6, anyone who raced at Renegade in Yakima, Washington was at the constant risk of getting a flat tire at any time due to the Goathead weed. You basically needed to have steel sole shoes to even walk through the pits!
All this said, I repaired a few leaking tires for friends and used a patch, never having any issues and the tires continued working until they needed replacement.
Old 10-22-2021, 04:02 PM   #7
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
The deal with the Goatheads should be fixed, in the pits @ least. They have made quite an effort to be rid of those ....... things.
I know it defeats the liteweight thing but has anybody used a tube to fix a persistent leaker?
Dave Noll, EF/S ,?/SA 6526
Old 10-24-2021, 08:35 AM   #8
Henrys Toy
Smile Re: Front Runner tires
Good morning,
I had used Regular passenger car tubes in my Moroso front tires for years when I raced at Westhampton on Long Island. It did stop the flat tire troubles, but tubes add to the overall weight of the wheel / tire combination. I found I was giving up a little after I started racing at Raceway Park in New Jersey, the pits were much cleaner. No balance or handling problems with tire tubes .but yes, a little heavier.
Respectfully,
Old 10-25-2021, 09:37 AM   #9
Run to Rund
Liked 54 Times in 27 Posts
My GM A body sits on Hoosiers year round, and they lose little air pressure over those months.
Old 10-25-2021, 05:35 PM   #10
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
I run Moroso DS-2, but I'd just patch what you have if I were you.
S/ST 51
S/C 53
