I`m building a 67 stock camaro small block and i gone use 20180 moroso oil pan, anyone who knows if it fits into the fram or do i have to do some modifications?
#2 | |
I prefer and use the approved Milodon oil pans and they fit like a glove and it clears and fits the Camaro frame.. |
Liked 1,002 Times in 203 Posts
Milodons have some fit, and leak issues also. My 30700 leaks in the corners from under the corner reinforcements, and also the curve of the pan rail is smaller than the standard 5/16 bolt heads.
#4 | |
Liked 520 Times in 176 Posts
I use that pan on my engine and the Fel Pro one piece gasket. I do seal it to the block, timing chain cover and rear main cap with coating of "grey" silicone. I also check the bolt hole locations as some don't line up as well as others. No leaks at this time. Respectfully, Henry Kunz 1534 H/SA |
Liked 28 Times in 15 Posts
