Old 10-28-2021, 09:42 AM   #1
thomas sheehan
thomas sheehan's Avatar
Liked 75 Times in 29 Posts
Default Easy way to help AHFS work
Do you want to see racers qualify with all out runs?
Do you want to make the AHFS system work.
Give the racer a reason to cut her loose!
How about a first round BYE?
Not just for #1..... but how about 1-10 byes in round one?
Do you know anyone that would rather run against someone in round 1 rather than take a BYE run?... (answer is NO)
If someone wants to take a chance that their -.90 run will get them in the top ten (while running their restrictor plate, they take a chance that others will bump them out of the BYE group.
Here's where we use "Out of the box thinking"... NHRA uses a "randomizer" after all qualifying is complete, and then lets everyone know how many bye runs there will be. One week there could be 10, next week 7, next week 5... who knows? Maybe they even guarantee 5 first round byes per race. Then everyone shoots for top 5
Just look at the guys that cut her loose at the end of the year to get #1 spots for nothing more than a first round BYE,10 more points, and not having to run anyone in the dreaded first round! If more people are chasing a first round BYE, more people go fast and make the AHFS work.... "It ain't that hard to do"
REWARDS BRING RESULTS
Tom Sheehan
SS GT/NA 1046
Old 10-28-2021, 12:36 PM   #2
GTS340
Liked 1,361 Times in 416 Posts
Default Re: Easy way to help AHFS work
And the ladder formula is?
GTS340 is online now   Reply With Quote
Old 10-28-2021, 12:49 PM   #3
thomas sheehan
....should not be an issue - just something different.
example #1 ... 64 car field
NHRA gave top 8 a bye run (the rest run rd 1 on a normal 56 car ladder).
rd two would be reladdered with the 8 byes and the 28 winners (new 36 car ladder).
It's not that hard.. with in the first couple of weeks, someone will have a new ladder book for all to use (for every situation available)
OR.....
Better yet
example #2.... (same scenario as example #1 - 64 cars with 8 byes earned)
Just use the standard 72 car ladder!
(1vs37, 2vs38, 3vs39... 8vs44)
All you would have to do is insert dummy entries called #BYERUNS into the qualified field for qualifier 37-44 droppng everyone else down 8 spots to fill out the 72 car ladder.
Easy Peasy... case closed
Tom Sheehan
SS GT/NA 1046
Old 10-28-2021, 01:42 PM   #4
GTS340
So 59 cars pay entry money. You need a 69 car ladder. No time and money involved there.
Old 10-28-2021, 01:54 PM   #5
GTS340
Just our special classes need this too. I'm sure NHRA would say "perfect"
Old 10-31-2021, 10:19 AM   #6
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
Kinda off subject, but if someone goes -1.20 and has to tear down, and is certified legal, and the run is under the current NHRA record, I think NHRA should give them the record. As it is, you get NOTHING for going -1.20 except the 'privilege' of tearing down and getting HP-what?
Mike Moller
NHRA 203 Q-R-T/SA
Old 10-31-2021, 10:40 AM   #7
SS/GSI
SS/GSI's Avatar
Liked 759 Times in 109 Posts
Thumbs up Re: Easy way to help AHFS work
Tom, I respectfully disagree with everything you and a lot of others have voiced on this forum regarding how to fix the AHFS system. Like most people with an agenda to get "soft" combinations HP, they only have tunnel vision for the FIX but do not see the big picture. Is there under factored combinations, YES!!! Have those competitors played within the rules of NHRA to keep their HP factors down, YES!!! Sorry nobody wants to destroy there combo to be #1 at a nothing divisional or national event!!!
What nobody here is mentioning is how "OLD" combos got HP!!! Class runoffs and rivalries within a specific class. Being the badest B/SA or GT/HA car use to mean something. But now everyone dodges everyone to avoid heads ups in the "eliminator"!!! Given the 30 newly added FS, FSS and FGT classes, manufacturer crate motor GT combos, the dozens of mid "80's & '90"s combinations in STK/SS added in the last decade, stockers running SS, the loss of shipping weights in GT and cars being able to run SS or GT with same combo...all that coupled with class runoffs being cut down by more than half, a Performers Award system that disappeared overnight, lowered quotas at National Events, an annual review period(instead of semi annual) and the price of engines being North of 50k in SS, ya I'm gonna say that getting HP will be nearly impossible moving forward!!!
So instead of trying to MF all the guys with soft combos by adding ridiculous measures on them(ie. checking weight at the scales, restrictor plates, 1000' increments +++) why doesn't the SRAC and the NHRA simply bring back what is proven to work???!!! OHHH and just curious on who will be the mathematician "chosen one" that will figure out everyone's backhalf splits, how fast they "could have gone" with 115#'s out of the car!!! No offense, but I'm not exactly confident in most peoples ability to do simple math.
But keep pounding your personal agendas...just like all the other special interests groups in Canada and the USA, I'm positive that you will get your way!!! If you guys want everyone to be the same...there index classes you can run! STK and SS are performance based classes!
PS: How did that whole AHFS at Indy thing work out for the less than 20% of racers that wanted it!!! That's what I thought...The problem with thinking other people are stupid does not automatically make you smarter than them. IMHO
Kevin Gaffney
1123 SS/GA
SS/GSI is offline   Reply With Quote
Old 10-31-2021, 01:09 PM   #8
1347
1347's Avatar
Liked 1,032 Times in 283 Posts
Give points to #1 qualifier, a little competition at getting points along with the bye run may help.
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 10-31-2021, 01:16 PM   #9
Kevin, Where are we going with this? I don't disagree with much of what you said, but what would be your plan?
Tom put forth his. NHRA isn't going to do it, but that's the theme here.
Old 10-31-2021, 01:47 PM   #10
Charley Downing
Liked 653 Times in 89 Posts
AHFS will never work with its current leadership. Now if Lonnie Grimm cleans house/ eliminates the problem, then it might have a chance but let’s face it AHFS has had the same problems 10-15 plus years now.
1. You can run -1.10 at an event and go to the next event and make 2 passes at -.55 to bring your average back to under-.80 making it safe from HP.
This window to lower your combo average are passes of -.85 to -.35. This window is way to big. I mean how can some make an argument that one weekend a guy runs -1.00 and the next weekend there making runs at below -.60. to pull the average down. There is no logic to this window. Personally, if a combo can run -1.00 then no runs under -.65 should count in lowering the class average
2. I Think the most important thing that will help AHFS work and put NEEDED performance back in the SS/STK class is going to a 48 or 64 car field at ALL National events (But INDY). Let’s face it the national event quotes are not going back to 80 plus cars per class at most national events so let’s just meet in the middle make all the quotes 70 cars per stk and ss. This will make guys step on there cars a little more frequently. I personal would like to see 48 car national event fields with around 60-65 car quotes. This would reward the #1 with the potential semi final bye into the final. I would leave points meet at 128 car fields and national open at all run field. This would create a kind of steppingstone affect for the class depend on you combos performance. This would also eliminate the 105 points Issue for winning a 6 or 7 round national event (East Coast VS West Coast) if all the National events were a 6 round max to win.
3. All runs of over -1.00 should have a min carb/TB check, casting # check and a PG if time permitting.
Charley Downing 3548 STK
Charley Downing is offline   Reply With Quote
