Go Back   CLASS RACER FORUM > Class Racer Forums > Factory Stock and Super Stock
Old 11-05-2021, 02:23 PM   #1
SSDiv6
Default New Comp Eliminator A/FX Class
The 2022 NHRA Rule Book amendments shows a new class, A/FX, for next year, for Cobra Jets, COPO Camaro's and Drag Pak's with a lot of creativity and freedom.
FACTORY EXPERIMENTAL
DESIGNATION
A/FX preceded by car number.
Reserved for 2019 and newer Manufactured Automobiles with Factory production engine of the same make. Manufacturer engines and bodies not listed in this section may be submitted for acceptance in Factory Experimental.
Currently Accepted makes/models:
Chevrolet (Camaro – COPO) – minimum weight 2,650 lbs.
Dodge (Challenger – Drag Pak) – minimum weight 2,650 lbs.
Ford (Mustang – Cobra Jet) – minimum weight 2,650 lbs.
All minimum weights listed above include driver.
Old 11-05-2021, 03:20 PM   #2
Andrew Hill
Andrew Hill's Avatar
Liked 174 Times in 39 Posts
Default Re: New Comp Eliminator A/FX Class
"Aftermarket planetary or clutchless transmission with a maximum of five forward speeds
and reverse permitted. Automatic transmission prohibited."
This class is going to be cool as hell!
3207 D/SA, C/ED
Andrew Hill is offline   Reply With Quote
Old 11-05-2021, 04:14 PM   #3
BRETV
Liked 776 Times in 199 Posts
The future Pro Stockers, very cool!!!!
Bret Velde
2003 ??/SA
BRETV is offline   Reply With Quote
Old 11-05-2021, 04:21 PM   #4
Carguy49
Liked 2,993 Times in 719 Posts
Bret Velde
2003 ??/SA
Just what I was thinking. Let's see who jumps on the bandwagon and just let's her rip. I am excited for this new class.
I didn't look at the rulebook amendments - what is the index??
Ron McDowell - Did Race
Old 11-05-2021, 05:12 PM   #5
jmcarter
jmcarter's Avatar
Liked 3,227 Times in 981 Posts
Future Pro Stockers, possibly even replacing FS if enough people make the changeover and take advantage of a bigger tire. If they phase out PS NHRA will probably keep it a “sportsman” class since the purse will no doubt shrink accordingly. Maybe they won’t muck it up with pulley changes for the sake of parity.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 11-05-2021, 05:36 PM   #6
Carguy49
I did some checking. Looks like it will be an exhibition class at first.
If it becomes a real class, I HOPE NHRA doesn't mess with it and let it stay all 3 brands (Ford, Chevy and Mopar). Otherwise it will be no better than Pro Stock is now, and Factory Stock. Just my 2 cents.....
Old 11-06-2021, 10:01 AM   #7
Pistol Pete
Pistol Pete's Avatar
Liked 798 Times in 212 Posts
I didn’t see where these cars are going to run in Comp Elim.
Or am I missing something ??
"Pistol" Pete Dutko
Old 11-06-2021, 02:59 PM   #8
Dyno
Dyno's Avatar
Liked 694 Times in 206 Posts
I read the description of the class. It reads very intricate and expensive to build.
Old 11-06-2021, 07:08 PM   #9
Charles Stewart
Liked 755 Times in 213 Posts
You can see more details and specs for thoses A/FX ,on page 48 to 59 of the Exhibition Rulebook, at the bottom of the rules section, on NHRA RACER.
Good reading...
Charles Stewart is offline   Reply With Quote
Old 11-07-2021, 11:59 AM   #10
Superfan1
Superfan1's Avatar
Liked 2,638 Times in 440 Posts
Smile Re: New Comp Eliminator A/FX Class
Let's all pray that the NHRA doesn't screw this up like they have done to the Factory Stock Showdown and, to a somewhat lesser degree, Pro Mod. This has the potential to be absolutely great!
Bill Seabrooks - superfan1
Bridgeport, CT
