Liked 184 Times in 113 Posts
Can a Torquehead System be used in place of an Opti - PCM In Stock?
#4 | |
Liked 2,361 Times in 558 Posts
If you want run a stock ECU, go ahead.... |
#5 | |
Liked 534 Times in 143 Posts
DISTRIBUTOR Any battery-operated, stock-type ignition permitted. Crank trigger systems prohibited unless OEM distributorless ignition. Distributorless ignition must retain OEM number of coils. See General Regulations 8:3. In this case for your LTjuan the Opti is considered distributorless and a crank trigger is permitted. One of the issues with the TorqueHead is the multiple coils. I don't know why you would want them over a single coil, but that is beside the point. Your combo only came with a single coil (it is plenty) and that is all that is permitted. |
#7 | |
Do not understand NHRA’s reasoning but that is the rule. It is a nice bolt on system and ECU easy to tune. Our B-Body clubs like them. Especially the Boosted crowd. Agree single Coil is enough. Until this weekend was fine using TunerCat for ODB1 PCM. Been a 15 year labor of love learning most of the Files. Excellent ECU. Opti is reliable. Just discovered it’s limits. Thanks for the help. D Last edited by Dan Fahey; 11-10-2021 at 11:16 AM. |
#8 | |
#9 | |
With all due respect, in lieu of trying to reinvent the wheel. Listen to the guys that are running the Opti-Spark system. On the long run, it will be more reliable, better performance and cost effective. |
#10 | |
Having a fight with Pat Cvengros over this RIGHT NOW ! Dan Where did you get that information from? I disagree since it clearly has a distributor with a single coil. Pat Cvengros - Pacific Division Technical Director (626) 250-2295 ---------------------------------------------------- My response !!!!! Found out mine is considered a Distributorless System So a Crank Trigger is fine.. D ---------------------------------------------------- Previous Conversation; No, crank trigger ignition systems are only permitted on distributorless ignition systems. If you switched to Super Stock you could run a crank trigger with the Opti spark distributor. Pat Cvengros Pacific Division Technical Director Pat thinks the Opti s not a Distributorless system ! So I am confused. Needs some help here !! Dan Last edited by Dan Fahey; 11-10-2021 at 01:14 PM. |
