Old 11-10-2021, 01:20 PM   #11
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: TorqueHead vs Opti
Follow up EMAIL from Pat !!
Dan,
Unless you have documentation from Chevrolet stating it is a distributorless system it’s not; so a crank trigger would not be legal.
1. Distributor: a device in a gasoline engine for passing electric current to each spark plug in turn.
Pretty clear to me you don’t have a distributorless system.
SO I am confused
Just sent Pat KRATLIF's response.
Pat's response is below.
Dan
Thanks for the heads up, we will have to look this weekend at Pomona.
As I mentioned previously, unless you have documentation from Chevrolet stating it is a distributorless system it is not.
Pat Cvengros Pacific Division Technical Director (626) 250-2295
Then sent GUMPS response...
Pat Responded
You can believe who ever you want,
I’ve answered your question based on how NHRA officials interpret the rulebook.
Crank triggers are not a legal option for the Opti Spark.
Pat Cvengros
Old 11-10-2021, 02:57 PM   #12
GUMP
Liked 2,354 Times in 554 Posts
Dan,
SO I am confused
Dan
Pat Responded
Pat Cvengros
So what you are saying is that you just rocked a boat that was on calm seas....
If enforced under this interpretation, this would park pretty much every LT car running Stock Eliminator! I'm pretty sure that Holley doesn't have a harness. I don't know about the other systems.
Keep being AWSOME Dan!!
Old 11-10-2021, 04:35 PM   #13
Hacksaw
Liked 312 Times in 175 Posts
Hard to put the worms back in the can after it's opened. Good going Dan !
Old 11-10-2021, 04:45 PM   #14
Dan Fahey
Dan Fahey's Avatar
Originally Posted by GUMP View Post
So what you are saying is that you just rocked a boat that was on calm seas....!!!
Y E A uh !
Out did Billy Nees today !!
Not a Dodge Manifold.
Did manage to squeeze Tomato paste out of a Rock !!
D
Old 11-10-2021, 05:27 PM   #15
Keith 944
Keith 944's Avatar
You continue to make friends every where you go! Lmao
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 11-11-2021, 08:32 AM   #16
Billy Nees
Liked 7,789 Times in 1,744 Posts
Not even close Dan. all you have done is start a conversation that doesn't need to be had.
Where does the OEM optispark pick up it's signal? From the crankshaft? Then it's a "crank trigger" system.
IMHO, (and I'll probably catch some heat for this) any OEM ignition system that uses a crank sensor and a cam sensor to sort out the timing events should be able to use an aftermarket type crank trigger system.
Billy Nees 1188 STK, SS
Old 11-11-2021, 10:54 AM   #17
Drunken DragPak
Liked 8 Times in 3 Posts
A crank trigger is nothing more than a crank sensor, the LT1 came factory with a crank sensor and nowhere in the rulebook says you cant use aftermarket sensors.
Drunken DragPak is offline   Reply With Quote
Old 11-11-2021, 11:39 AM   #18
Dan Fahey
Dan Fahey's Avatar
Billy and DDP;
Then you better have that conversation with Pat Cvengros!
What we say does not count if he believes otherwise.
These are not our rules !
Pat is the arbiter not us !
Read the exchange….
I ran into the limits of the OBD1 PCM.
Sought advice from people more experienced than I.
The 8.3 rule was confusing comparing available products out there.
So contacted a Technical Director.
The feedback from CR is in conflict with what Pat said.
So before proceeding over the rulings cliff.
I want clarification !
Wouldn’t you?
D
Old 11-11-2021, 11:54 AM   #19
Billy Nees
Dan, the LT-1s that I am dealing with use a Holley PCU wired into the opti-spark! How can that be illegal?
Old 11-11-2021, 11:59 AM   #20
GUMP
Maybe you should point out to Pat that the later LT motors had a crank sensor?
You are not a very popular guy right now. Maybe it's time for you to fix this?
A simple google search will reward you with a photo of the later timing cover that clearly has a boss for the crank sensor....
