Old 11-14-2021, 03:56 AM   #21
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Default Re: 7.45 Dial for Bill O'Connor
Originally Posted by Rory McNeil View Post
But even if the dial on the score board WAS wrong by 10 seconds, is it not still the drivers responsibility to check and ensure the correct dial is displayed before putting the 2nd stage light on?
Technically you need to check this before lighting the first stage bulb per the rule book, but your general point is correct.
Incorrect dials don’t happen often, in my experience, but they do happen and it’s part of your job as a driver to verify it. My car doesn’t go in low gear after the burnout until the dial-in is up and correct.
S/ST 51
S/C 53
Old 11-14-2021, 01:56 PM   #22
Bruce Fulper
Liked 54 Times in 33 Posts
As an NHRA announcer and worked at Pomona for seven years until the new bunch took over and hired "whatevers," catch me in the pits sometime and I'll tell you what goes on. I can't write it here.
Bruce Fulper is offline   Reply With Quote
Old 11-14-2021, 02:14 PM   #23
Warren Evans
Warren Evans's Avatar
Liked 1,595 Times in 190 Posts
So maybe some insight here... The computer operator may have put in 7.45 instead of 17.45 and hit the key to advance the pair to the active state. THAT is the number that Live Timing and the NHRA timing screen sees. When the operator corrected the dial, that does not always push to Live Timing or the timing screen. It's a quirk / bug / ??? of the data capture programs that NHRA built and happens more often than you think. The important part is that the Compulink got and processed the corrected number. Now, if it should have been 17.45 or 17.05, that is a shoe polish issue.
Warren Evans is offline   Reply With Quote
Old 11-14-2021, 03:46 PM   #24
Liked 10,820 Times in 2,249 Posts
Thanks Warren!
Old 12-02-2021, 01:41 AM   #25
bill7947
My time slip showed a 17.45 dial for the round 2 race. I don't know where the 7.45 came from. I broke out by a bunch but thats a whole other story.
bill7947 is offline   Reply With Quote
Old 12-02-2021, 10:55 AM   #26
Barry Polley
Guest
Posts: n/a
Started in the semis for us , Dial in board had a mind of its own. They assured us it was correct . Same thing in the final.
Old 12-02-2021, 01:32 PM   #27
Shake & Bake
Liked 37 Times in 33 Posts
Isn't your dial-in on the scoreboard at the end of the track also before the run?
Shake & Bake is offline   Reply With Quote
Old 12-02-2021, 04:14 PM   #28
Barry Polley
Guest
Posts: n/a
Yes, that was the issue. Finish line board/ boards were wrong.
Old 12-02-2021, 05:47 PM   #29
Shake & Bake
Post Re: 7.45 Dial for Bill O'Connor
Oh, Got'cha!
I just assumed that there was also another board with your dial-in on it when you pulled into the water box you could glance up at in the center of the lanes to check your dial-in besides the scoreboard at the far end...
