#41 |
Liked 289 Times in 91 Posts
....and whom are you referring too...?
RJ |
#42 | |
Tim worked for Delphi, Cummins and Penske Racing prior to joining NHRA. I have always enjoyed the technical subject conversations that have taken place with Tim and he has always backed up his responses with an email. |
#43 |
Liked 2,359 Times in 557 Posts
The part numbers for the LT1 crank sensor.
12552427 Timing Cover 10190917 Reluctor Wheel 19170837 Crank Sensor I have forwarded this to Pat for his consideration. |
#44 |
Liked 208 Times in 45 Posts
I got a call from Pat wanting to know if I ran a crank trigger, supposedly called several other racers wanting to know the same.
Time will tell what will happen. thanks Dan, |
#45 |
#46 |
Liked 150 Times in 41 Posts
Pat called me today.
#47 | |
Liked 184 Times in 113 Posts
NHRA does it all the time. Stock Eliminator does not lend well with the aftermarket industry. Should be some sort of rule allowing bolt on upgrades. Crate Motor offered some of that. Like allowing under used engines such as big Caddy engines in BOP cars. Bolt on 4bbls like on the mid70/80 Mustangs and Monzas. Under used Ford 300cuin 6 with a 4bbl. Or for that matter let the 6 cylinder AMC guys have the better heads. Or flattop Pistons for the Low compression BOP cars. 74 Firebird with 10:1 compression would be a A stocker. Much like Pure Stock Drags and FAST do. Just my 2 cents |
#48 | |
Liked 564 Times in 66 Posts
Bill |
#49 |
Liked 880 Times in 311 Posts
What will Dan get for Christmas?
Adger Smith (Former SS) |
#50 | |
Liked 238 Times in 78 Posts
