Old 11-22-2021, 04:50 PM   #1
Tex013
Liked 44 Times in 26 Posts
Default Oil pan gasket choice for big block mopar
Hi ,
what would be considered best oil pan gasket for a 440 mopar ?
Milodon tin oil pan in a 68 Satellite .
I have used cork/rubber , a couple bolts loosen and it weeps . Even with loctite or silicone on threads .
I have the Felpro #1808 , rubber/fibre core and #1834 steel core .
Preferences ?
I am using a World iron block .
Thanks .
Tex
Tex013 is offline   Reply With Quote
Old 11-23-2021, 09:19 AM   #2
Liked 10,852 Times in 2,254 Posts
Default Re: Oil pan gasket choice for big block mopar
Before damper and flex plate is in stalled and after pan is installed with any gasket, I put silicone all around the outside of the block/ pan joint.
Old 11-23-2021, 04:26 PM   #3
Al Wilson
Liked 109 Times in 38 Posts
The last one I used when I had my BB Mopar was a nylon one that had the windage tray built in. They make stroker version also. Never had a leak with it.
https://www.summitracing.com/parts/m.../make/chrysler
Al Wilson
NSS 7160
W201 stock
Al Wilson is offline   Reply With Quote
Old 11-23-2021, 04:53 PM   #4
Tex013
thanks guys .
Larry its in the car so cant go to that level . Al will look into those , may not work as i use a road race pan ?
Tex
Old 11-23-2021, 08:24 PM   #5
If you want to you can. Drop the drag link and trans. Remove flex plate and damper. While it’s off check a bearing or too. Clean and resemble. Not a piece of cake but doable.
Old 11-23-2021, 11:00 PM   #6
Tex013
wowser . no way Jose' !.
Thanks Larry but i might pass on that . I actually swapped in my transbrake transmission only 3 weeks ago . Had the pan off yesterday . I think its mostly wicking down a couple of bolts that line up with cap cross bolts . No time to check bearings needed to get home . Its my daily street/strip satellite .
Tex
Old 11-24-2021, 07:51 AM   #7
Sounds like a fun ride.
Old 11-24-2021, 04:37 PM   #8
Tex013
thanks Larry .yes a lot of fun and almost cheaper than Stock . It runs 10.20s@ 3780lbs but a few more cubes than yours
Tex
