Liked 227 Times in 74 Posts
All mineshaft does is protect the fast combo’s. Mineshaft is not determined by the weather it is only considered mineshaft when at the conclusion of qualifying the first competitor in the bottom half of the field is -.850 seconds or faster under the class index. To prove the point is Indy the weather sucks that time of year with high temperature, humidity and low barometric pressure. If we used Indy as the rule for mineshaft then almost all the race would be considered mineshaft.
The AHFS will not work affectively with the mine shaft rule in affect. Let’s talk about the AHFS real quick. All it does is try and keep the fast combo’s all at 1 second under. If you get horsepower you get weight and only slow down a little bit and probably still can run 1 under. If you get hit several times you are now a high 90 under combo. The AHFS doesn’t destroy combo’s if running high 90 under is considered destroyed? For the people that are complaining about not being able to run their car all out, then go to your local track for a bracket race and you can run as fast as you want without getting HP. I think the mineshaft rule should be removed. If NHRA were to take a vote on removing the mineshaft rule it would be gone because it only affects the fast combo’s and there are way more slow combo’s then fast ones. No brainer. Here are some facts on how many runs were affected by the mineshaft rule. 10% of the races were mineshaft 7 out 65 races were Mineshaft 54% of all 1 second under runs were mineshaft 238 mineshaft runs out of the 435 1 second under runs How many combo’s will not get review because of mineshaft I do not know? So how is the AHFS supposed to work if half the runs don’t count towards it?
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
Liked 2,359 Times in 557 Posts
I don't understand your thought process here. Do you consider yours one of the slow combinations?
I've seen where you have made some pretty fast runs in the past (1.10). I also see where your combination had a reduction at some point. Where does your combination sit in your master plan? |
Liked 10,835 Times in 2,252 Posts
I think we all try to play by the rules.
Larry, I "fixed" your reply! ;-)
Liked 699 Times in 202 Posts
Yep, if there were no rules we all would be .90 racing or bracket racing and it just wouldn't be as satisfying. Even though my car is still not finished (getting close) I get a lot of enjoyment out of building a car that I hope can get to 1 under. I previously built a super street car and then a super gas car, not too much worry about when building the car, just build it fast and slow it down with a stop. For my new stock eliminator car I've tried to consider the performance aspect of every decision and every nut and bolt on the car.
Billy both are true.
Here in the south, yes I know we live above I-10, we are always "fixen" to do something. I'm fixen to go to town after some KFC chicken and fixins as soon as I finish fixen the car. Ya'll know I talk slow. |
Liked 101 Times in 27 Posts
For the mentally impaired senior racers........what is the perfect pass to make everyone happy in regards to protecting the combination from horsepower ?????
NHRA AND IHRA STOCK ELIMINATOR 2772 |
Liked 880 Times in 311 Posts
Larry,
Here in the South?? North and South Confederacy style: The Confederacy included the states of Texas, Arkansas, Louisiana, Tennessee, Mississippi, Alabama, Georgia, Florida, South Carolina, North Carolina and Virginia. Jefferson Davis was their President. Maryland, Delaware, West Virginia, Kentucky and Missouri were called Border States. But I understand how yo Fix'in to be upset about your Southern charm and dignity being questioned by an Arkansas Boy.. LOL! Billy did fix it.... Only our Cajun buddies live below I-10
Adger Smith (Former SS) |
#9 | |
Perfect Pass!
Liked 231 Times in 107 Posts
Speaking of HP Welfare. When will it be out?
