Old 12-02-2021, 12:31 PM   #1
Ron Ortiz
Ron Ortiz's Avatar
Liked 317 Times in 103 Posts
Default Motorhome selection.
Looking for motorhome for my U/SA wagon. Open trailer, wagon, golf cart, etc weighs about 8,000 pounds. Seems class C's don't have tow capacity, class A's are too long and rated at 5,000 lbs, would like to stay 28' or under.
No, I do not want to go the truck/enclosed trailer route.I know it is the most economical, but me and the crew are getting up there in age and want some comfort and a little room.
Also, some comments on the standard Triton V10 as a power plant, I would like to go diesel. And why do people avoid Chevrolet.
Thank you in advance for the comments.
Ron Ortiz 2102 STK
Ron Ortiz is offline   Reply With Quote
Old 12-02-2021, 12:55 PM   #2
Keith 944
Keith 944's Avatar
Default Re: Motorhome selection.
Sounds to me like a super C would be ideal for you
many of those have diesel engines. Some under 28 foot and no special license required. and heavy enough to tow just about anything. Or do as I did and just build your own lol
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 12-02-2021, 01:01 PM   #3
J.R. Haddad
Liked 1,470 Times in 308 Posts
Ron, I just went through this exercise. Everybody told me to get a diesel,
and I agree they have more power. However, everyone I know, in the
area I live, spends a ton on diesel maintenance, and I wouldn't know
how to fix one. So, knowing I was going gas, I would have liked an
8.1 Chevy, for the Allison Trans, but I couldn't find one in a Motorhome I
liked. I ended up with a Ford V-10, and I'm OK with that, as they are
supposed to get 2 miles more per gallon. Do they, I don't know. Like
you, I'm after the comfort, I like having real food and cold beverages
and cold air conditioning. Nothing is cheap to tow with anymore,
so you might as well be comfortable.
J.R.
J.R. Haddad is online now   Reply With Quote
Old 12-02-2021, 01:22 PM   #4
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Check out the Thor Axis model. I have the 25.2 version. 26 feet long ford e450 chassis with standard V10 engine. I pull a 24 ft enclosed aluminum trailer. It weighs 7500 with all the spare stuff I carry in trailer. Gets 8.5 -9 mpg. I tow at 65-75 mph no problem.
Old 12-02-2021, 03:32 PM   #5
jmantle
Liked 172 Times in 81 Posts
Had a 32' class C on a Chevy Kodiac chassis with a 6.6 Duramax, towed our 24' enclosed with no problem and was easy on fuel. That said, it was a 2005 LLY, before all the excess emission stuff.
Jim Mantle V/SA 6632
Jim Mantle U/V/SA 6632
jmantle is offline   Reply With Quote
Old 12-02-2021, 04:36 PM   #6
jmcarter
jmcarter's Avatar
Liked 3,198 Times in 977 Posts
I thought Joe Costello had done a “Inside the Pits” segment that included your rig….got a link? I couldn’t find it.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 12-02-2021, 04:53 PM   #7
Rory McNeil
Regarding gas mileage with a Ford V10, although it is not a motorhome, I have a 99 F350 Dually 2wd with a V10, 5 speed, and 3.73 gears. Last year, I did a 4000 mile move from the West coast of Canada, to the East coast. My truck was loaded, the 24 foot enclosed trailer was packed full of car, tools, parts, furniture etc, total combined weight was right around 20,000 pounds on a truck scale. I kept tracked of my gas mileage for the entire trip, the worst mileage was 6.97 MPG going thru the Rocky Mountains in British Columbia and Alberta, best was 8.59 MPG on the flat land.I towed in 4th gear (no overdrive), at 62-63 MPH, taching about 2700 RPM. Empty, the truck has gotten 15 MPG on the freeway in 5th gear. I really like the V 10, very smooth and quiet. My truck has the early version, which has 2 valves per cylinder, later in the mid 2000s, Ford went to a more powerful 3 valve version in the F series trucks, but my understanding is that the Econoline and motorhome platforms were all the 2 valve model.
NHRA 6390 STK
M/S 85 Mustang
Old 12-02-2021, 05:00 PM   #8
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I have a 25’ Class C E-450 V10
Tow a 26’ enclosed with dragster and lots of spare parts
Have used it since 2014 with no problems
I re-enforced the hitch and rear frame. Added air bags, good shocks and steering stabilizer up front. Have a real good hitch with sway control.
It’s certainly not the best rig possible but has worked fine
I don’t have a lot of room at home for anything bigger and used my Duramax pickup with a Lance camper for over 10 years.
My little motorhome is way more comfortable
If I had it to do over I’d have bought the next larger length MH. About 2 feet longer overall length and wheelbase. The longer wheelbase would handle better I believe.
Gas mileage is around 7-8 at best with or without towing. 4:56 gears and 25-2600rpm+ at 65/70+
5 speed AOD trans.
Rich Biebel
S/C 1479
Stock 147R
Old 12-02-2021, 09:04 PM   #9
Keith 944
Keith 944's Avatar
They did and I never saw it either I know there was a problem with my stereo playing Van Halen they said they wouldn’t be able to use that due to copyright so I’m not sure what happened. And I call my motorhome a redneck renagade. Maybe problem with that too. I would post a pic of it but not sure how I don’t have a photo account
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 12-03-2021, 12:24 PM   #10
NSSGTO
NSSGTO's Avatar
Liked 24 Times in 17 Posts
My advice go with a Super C on a Chevrolet Kodiak 5500 Chassis.
I had a E450 32ft with the V10. It pulled my 24ft @ 8000lbs ok. I braced the rear frame, Coil over shocks, Air Bags, sway bar, load distribution hitch etc. Still just pulled OK. Gas mileage was 6MPG no matter what and it only had a 38 gallon fuel tank and only a 35 gallon water tank. Problem was stopping it. If you had to hit the brakes hard it would slide the front tires. After about 6-8 hrs I would be wore out.
Sold it and bought a 2006 Gulfstream Super C 36ft with the Duramax on a C5500 Chassis. It had airbags on it, I added front and rear track bars and Bilstein Shocks. I also added a PPE programmer and did the EGR delete.
I pull a 28FT ATC with car and golf cart with total weight of 10,500lbs. Pulls it with no problem, Stops well, has a 100 gallon water tank, and a 80 gallon fuel tank. Pulling the trailer it gets about 10MPG. Flat towing my Jeep Rubicon it will get close to 12MPG. Can drive one handed and go all day if needed.
Here's one for sale
https://www.ebay.com/itm/11512229660...AAAOSwo8php~gO
NSSGTO is offline   Reply With Quote
