#71 |
Liked 54 Times in 33 Posts
I've got a 2 door that's been sitting here for ten years. Nice little car. Stick. Got for parts for the now defunct S/S project. It has that alarm problem where it fires up for about three seconds then shuts off with a dash light ALARM light coming on. Need to fix that first. Or bypass it. Anyone know about that?
#72 | |
Liked 704 Times in 281 Posts
#73 |
Yes. Chip style. I've tried various online "remedies" none have helped. A long time a ago there was a fix that involved crossing some wires below the column but I misplaced the instructions and at the time wasn't too worried about it as I thought I was going to part it out. Well, it's a complete nice car so I might as well use it as a Grade Point Granny.
#74 | |
Liked 216 Times in 77 Posts
#75 |
Ok. I'll look for it. Thanks
#76 |
What year and make. VATS needs interrogator to determine what chip number. There 15 numbers. If it is not the exposed type chip and it's the one sealed in head of key then it requires the 3 ten minute intervals with key on. Also depending on year the connector inside switch may be bad. Requires new switch assembly and possible 3 ten minute intervals again.
#77 |
Liked 351 Times in 120 Posts
Pull the Ecu and send it out and have the vat delete and tune done. Face Book, he does not answer phone but will reply on {TBG tuned} up in Iowa ,does it. Best money you will spend. Tom
Tom Meyer 5240 SS Stock ??? Last edited by Tom Meyer; 12-05-2021 at 12:25 AM. |
#78 |
Phone # ?
