Old 12-13-2021, 06:53 PM   #1
Pete Lanciers
Pete Lanciers's Avatar
Liked 627 Times in 156 Posts
Default New HP posted
This just in:
2021 End of Year Stock, Super Stock Horsepower Adjustments Announced
https://www.nhraracer.com/apcm/APCMv...?a=72391&z=132
Horsepower Adjustments – From Competitor Requests
https://www.nhraracer.com/apcm/APCMv...?a=72390&z=132
Pete Lanciers
PAL Automotive Racing
Stock 7801
Pete Lanciers is offline   Reply With Quote
Old 12-13-2021, 08:00 PM   #2
J.R. Haddad
Liked 1,471 Times in 308 Posts
Default Re: New HP posted
I must have confused something. I didn't think you could apply for a
H.P. reduction if your combo had already received horsepower.
J.R.
J.R. Haddad is offline   Reply With Quote
Old 12-13-2021, 08:34 PM   #3
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
J.R.
That's what I was told........hmmm must be a special case
Old 12-13-2021, 10:21 PM   #4
rboyle
rboyle's Avatar
Liked 591 Times in 163 Posts
Which combo received the refund of HP that was penalized recently? Just curious as I have no idea.
Old 12-13-2021, 10:28 PM   #5
Liked 10,849 Times in 2,254 Posts
The sad part of this is, in three engine NHRA did not follow the rules, ie. the most reduction a combo can receive on a request is 2.25% with any part of a fraction being rounded up to the next number.
Three engines with incorrect Hp reduction are
287hp x2.25%= 6.4575 rounded up to 7 hp. 287 -7 = 280 hp not the 279 hp showed.
255hp x 2.25% = 5.7375 hp rounded up to 6hp. 255 -6 =249 hp not the 245hp showed.
207hp x 2.25% = 4.6575 Hp rounded up to 5hp. 207- 5 = 202 hp not the 201 showed.
Two out of the three mistakes could be typos but not the reduction of 10 hp on the 255 hp engine with a reduction of ten hp
Like my friend Al would say “ It doesn’t cost a thing to pay attention “
A 10 hp reduction on the 255 hp engine is 3.91% reduction the largest reduction listed is 2.25%,
go figure !
Old 12-14-2021, 12:13 AM   #6
Paul Wong
Liked 419 Times in 85 Posts
A 10 hp reduction was because of a previous clerical error. Not a basic reduction in horsepower request.
Paul Wong is offline   Reply With Quote
Old 12-14-2021, 07:42 AM   #7
Glenn Briglio
go figure !
How do you get a decrease in hp when the old hp is higher than factory hp on two combo's listed?
Old 12-14-2021, 08:07 AM   #8
The AHFS is a program based on actual run data compiled from all available runs at NHRA national events. The data-based format provides the ability to calculate average performances for any class and/or engine combination in Stock and Super Stock. The trigger point for the system is 1.00-second or more under the respective index, and must be produced on two different occasions. Engine-combination averages and class averages are then computed and analyzed to determine if a change is warranted. The amount of change is calculated on a stepped percentage basis. Where applicable, adjustments will be effective for the specific car model or body style being evaluated. An automatic adjustment is instituted outside the two-time a year process when a 1.20 and under run is recorded during any NHRA event.
Does the last sentence in the above paragraph end the not in play AHFS at National Opens?
Old 12-14-2021, 09:00 AM   #9
J.R. Haddad
Larry, would the first sentence make it run data only from "Nhra National
Events" ?
J.R.
Old 12-14-2021, 09:07 AM   #10
KRatcliff
Liked 534 Times in 143 Posts
If it did then they would need to take this out of the first paragraph because the two sentences would be in conflict with each other. I don't think anything has changed for the National Opens. It doesn't appear that the AHFS is in effect there.
"No runs made during exempt events, National Opens, test and tune, time trials, 1/8th mile events or races within a race (i.e. Jegs Allstar eliminations, Stock / Super Stock Combos or other races that are not part of a season long points championship) are included in any review."
KRatcliff is offline   Reply With Quote
