Old 12-16-2021, 05:34 PM   #1
SSDiv6
Default Optispark Rule Rule Update
On the 2022 Rule Book Amendments released today by NHRA, there is a rule change applicable to the Optispark.
It reads as follows:
SECTION 11A: STOCK, ELECTRICAL:8, DISTRIBUTOR (Page 12)
(12/16/2021)
Any battery-operated, stock-type ignition permitted. Crank trigger systems
prohibited unless originally OEM equipped with crank/cam sensor (removed-distributorless
ignition)
. Distributorless ignition must retain OEM number of coils. See General
Regulations 8:3
https://www.nhraracer.com/Files/Tech...12-16-2021.pdf
Old 12-16-2021, 09:51 PM   #2
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,389 Times in 505 Posts
Default Re: Optispark Rule Rule Update
So any EFI car that came with crank and cam sensors can now run a crank trigger?
'65 Mustang SS/L & L/SA
Old 12-17-2021, 09:40 AM   #3
SSDiv6
That is the way I interpret the rule change.
Old 12-17-2021, 06:26 PM   #4
Rob Petrie E395
Liked 216 Times in 77 Posts
Ok so when they say. “Crank/cam”. Are they counting the optical
sensor in the optispark as a crank or cam sensor? Because the earlier LT1”s do not have an actual crank trigger mounted in the timing chain cover. Like the later models do. They rely totally on the optispark to handle that. Not nitpicking. I own one and want to make sure I’m ok.
Old 12-17-2021, 11:04 PM   #5
e vassar
Liked 273 Times in 109 Posts
What year is your car?
If I'm not mistaken Gump told us previously that GM added crank sensor in 96 to smooth out minor mis-fires...I'm sure he'll be here soon to confirm or deny
Old 12-18-2021, 01:04 AM   #6
GUMP
Claim the car as a 1996-up....
Daren Poole-Adams
NHRA Stock/SS 2007
Old 12-18-2021, 12:28 PM   #7
Grover
Liked 6 Times in 4 Posts
Thanks glad mines a 97-98. A shame though the pot got stirred?
Grover is offline   Reply With Quote
Old 12-18-2021, 10:53 PM   #8
e vassar
Since we're talking 4th Gens.
I noticed NHRA just added the 98 Camaro to the guide....with the LS .Does it automatically get the same HP as the 99?
Old 12-18-2021, 11:44 PM   #9
countrypuppy4865
countrypuppy4865's Avatar
Liked 229 Times in 71 Posts
Yes
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 12-23-2021, 02:49 PM   #10
west coast
Liked 230 Times in 75 Posts
So what Combo's would be able to have a crank trigger now? I email NHRA and they said my combo could not have a crank trigger. Is it only the camaro and firebird this affects?
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
