Old 12-27-2021, 09:30 AM   #21
e vassar
Liked 271 Times in 107 Posts
Default Re: Can We Un-ring The Bell
Originally Posted by GUMP View Post
I know that this is a big concern for you. How prevalent do you really think it is?
Maybe random review of data by tech would help ease your mind?
I thought the thread was about roller rockers and sold lifters etc. But this is about out and out CHEATING.
You know what they say.... cheaters gonna cheat...so if you remove legal electronic boxes that can be modified to cheat.....then wouldn't the cheaters just use a smaller box well hidden?
Old 12-27-2021, 09:38 AM   #22
Billy Nees
Liked 7,790 Times in 1,744 Posts
Daren, I was hoping that you would respond.
In answer to the first part of your question, I'll ask you a simple question, do you think that there are Racers taking advantage of the rules (cheating) when it comes to their engine combination? Do you think that certain Racers would "manipulate" a situation if it could give them an un-fair advantage over the competition?
I would have to say that a "random review" of a LOT of things both under the car and under the dash would "help ease my mind".
This IS the 21st century!
Billy Nees 1188 STK, SS
Old 12-27-2021, 09:46 AM   #23
Billy Nees
Ya know, a long,long time ago, roll-out counters and delay boxes weren't "CHEATING". They were perfectly legal because NHRA didn't know what they were or that they even existed.
Old 12-27-2021, 09:49 AM   #24
Liked 10,789 Times in 2,242 Posts
Not knowing or accusing but to us uneducated or educated, it looks like a drive by wire “New” car would be the perfect weapon of choice. Can ECU’s follow a driveshaft curve like it follows a timing or fuel curve? I would say yes.
At the PRI show a few years ago I and about 60 to 80 more attended this informative ECU class and sales pitch. The list of benefits seemed endless, but the second and third benefit listed, as I remember, was “Run Tracing” and “Traction Control”!
Old 12-27-2021, 09:52 AM   #25
rognelson777
Liked 135 Times in 74 Posts
ignition boxes. how about run stock ignition. points and condenser if that is what it came with. As a person that was considering getting in to stock racing a few years ago, after looking at the rules decided not to and all i needed was to build a motor and upgrade clutch.car run under index as it was setup but not much more. I find it interesting that you better have the correct hood on your car for the combination you run but you can run almost any ignition you want.
rognelson777 is offline   Reply With Quote
Old 12-27-2021, 10:44 AM   #26
GUMP
Liked 2,354 Times in 554 Posts
You know that's a loaded question!! I think that the vast majority of racers would pass a teardown.
There are a lot of legal ways to manipulate a situation. They are open to every racer.
I am for that too. I think that it would be healthy for the class if Tech would take a look at racers data from time to time. I had no issue sharing all of my run data at Indy. To me, that makes a lot more sense than chasing wires.
Yes it is! We live in a time where there is so much real-time information available to us that a cheater should be pretty easy to spot.
Personally, I still feel that I beat myself way too much to worry about the guy in the other lane!
Daren Poole-Adams
NHRA Stock/SS 2007
Old 12-27-2021, 11:08 AM   #27
Billy Nees
and yet there are few, if any that ever get "spotted"! Is this because there aren't any to "spot"? Is this because there's no-one out there to "spot" them? Do the people in charge of doing the "spotting" know how to use all of this "real-time information" to put it to good use? Or are they just turning a blind eye to it all because (in the grand scheme of things) we just don't matter?
Old 12-27-2021, 12:03 PM   #28
tavirace
Liked 20 Times in 14 Posts
To me it seems the carburetor rules are outdated, high end cars with replacement blocks aluminum heads and trick transmissions are then forced to put some junk on it that can barely be found from 50 years ago.It would bring more combinations into it.
tavirace is offline   Reply With Quote
Old 12-27-2021, 12:26 PM   #29
Examples?
Old 12-27-2021, 12:34 PM   #30
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
There is a choice as to which class you decide to run. If you run a carb class then you have to run the correct size and style carb. If you don’t like a carb then you can run a FI class. In super stock you can run a FI combo in an older style body in GT or FGT classes if you want to get away from the carb. Not sure anyone would be in favor of changing the carb rule in stock or SS. Personally I like my QJet.
Mike Pearson 2485 SS
