Old 12-31-2021, 12:11 PM   #21
Billy Nees
Liked 7,854 Times in 1,750 Posts
Default Re: Throttle Limiters
Originally Posted by GUMP View Post
What would happen if the NHRA policed all those restrictor plates, disconnected secondary mechanisms, and throttle travel restrictors, etc.?
The only thing that I have an issue with is on a carburetor combo, the Racer is allowed 2 OEM type base gaskets. If you can find a base gasket with a smaller hole than the carb then go for it! I think the EFI restricter "plates" should go. They should have to adhere to the same 2 OEM gasket deal as the carb combos.
As far as "throttle stops", as long as they are mechanical and unable to be manipulated as the car is going down the track, I'm OK with them.
Billy Nees 1188 STK, SS
Old 12-31-2021, 12:17 PM   #22
Rory McNeil
Many years ago, NHRA was looking at the wiring of the Idle Stop on Quadrajet carburetors. It appears some racers found a way to use it as a throttle limiter by using a toggle switch.
As I stated earlier, racers are creative and there are many ways to skin a cat. (Sorry Cat Lovers... )
Considering the short travel length of the electric solenoid used for these anti run on throttle closing devices, if you are running quick enough to run index on less than 1/4 throttle opening of the primary side of a Quadrajet, I would have to think that is a very underfactored combination!
NHRA 6390 STK
M/S 85 Mustang
Old 12-31-2021, 01:21 PM   #23
4543
Liked 647 Times in 140 Posts
So it’s ok for a carb racer to run a smaller gasket than carb but if an EFI guy finds one it’s not ok. Just think they should be treated the same. Mike McMahan 2543 H/SA
4543 is offline   Reply With Quote
Old 12-31-2021, 01:23 PM   #24
Billy Nees
THAT isn't what I said!
Old 12-31-2021, 01:40 PM   #25
4543
I’m just trying to understand. Isn’t the effect of what you said the same?
Old 12-31-2021, 01:51 PM   #26
Billy Nees
You're allowed 2 OEM type gaskets, IF you can find a gasket with a smaller hole in it then go for it! But it's gotta be a GASKET.
The EFI guys are making steel and aluminum plates and putting them between the throttle body and the manifold.
Old 12-31-2021, 02:03 PM   #27
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Why would you need 2 gaskets other than to put one on each side of the restrictor plate?
S/ST 51
S/C 53
Old 12-31-2021, 02:07 PM   #28
Billy Nees
Some carbureted combos like a larger "plenum" under the carb. Some don't.
Old 12-31-2021, 02:07 PM   #29
Lenny5160
Lenny5160's Avatar
Originally Posted by PozQB14 View Post
I use a grid, you can look at my data if you'd like at any time. But nowhere that I have seen can you plug an ET in anywhere. There's a G-Meter that works with a grid, or basically a driveshaft sensor, that you can run which I'm 100% against and should be illegal on every car in the staging lanes in Stock and Super Stock. Those can easily be policed in the lanes or at fuel check or any damn place.
My post was made in jest, poking fun at all the fear and paranoia around the Grid. You can read more in the “Un-ring the Bell” thread.
Yes, there are illegal accessories available for it, but you can hook up illegal boxes to just about any ignition system if that’s what you want to do.
I understand that there could be a legitimate argument that any aftermarket ignition system does not belong on a Stock Eliminator car, but that’s a different argument.
S/ST 51
S/C 53
Old 12-31-2021, 04:03 PM   #30
e vassar
Liked 272 Times in 108 Posts
Is this the selenoid that opened the throttle a little when the AC was turned on,to maintain idle speed?
I knew a racer years ago that had one of these on a stocker,but I think he was using it for a staging device. Flip a switch and it holds the throttle open for you.
