Liked 6 Times in 4 Posts
I'm running a part# 34G10 Griner billet aluminum Transbrake Valve body in a GM Turbo 400.
I know they are no longer made. My question is, does anyone have a source for a replacement solenoid? TIA... |
Liked 239 Times in 114 Posts
Is it an external solenoid or an internal solenoid ? You may be able to call up Coan and ask them also .
Liked 13 Times in 9 Posts
4 years ago I sent my Griner trans brake solenoid to Extreme Automatics in Amelia, Ohio and had my solenoid rebuilt cost $100 then and haven't had any problems with it.Phone # 513-898-0553
Liked 333 Times in 180 Posts
you might try Cope Racing Transmissions in Indiana 219 -374- 0100---he has made a "new" solenoid that replaces the Griner unit for some Transmissions not sure if a TH 400 is one--- but his unit uses a new machined aluminum billet solenoid housing and a common Powerglide solenoid--- as you know Griner died a while back and the solenoids he supplied HE PERSONALLY made each and every one so the source and the secrets went to the grave with him---I would call Cole and see if he can help since no one else seems to be making solenoids any more--- Good luck FED 387
#5 | |
Liked 920 Times in 259 Posts
Showing the Griner 400 stuff on his website. This guy got his Mopar stuff. He may be helpful also. He is In Indiana. http://www.727specialist.com/ 219-718-3542 |
Liked 883 Times in 237 Posts
check with ATI , they were selling the Griner valve body for a while.
