Old 01-28-2022, 12:13 AM   #21
older racer
Liked 68 Times in 26 Posts
Default Re: Where is it legal to add ballast?
at end of track? woodburn?? lol
older racer is offline   Reply With Quote
Old 01-28-2022, 09:32 AM   #22
SSDiv6
There are two narratives to adding weight to a racer car:
  1. You add or remove weight to just change classes without caring about the effect on the suspension and percentage of rise.
  2. You add or remove weight to change classes, from specific locations, knowing how it will affect the suspension and percentage of rise.
As others stated, if you ever have an opportunity, scale the car and check the instant center and variations by placing weight for different classes at various locations and document your findings.
Old 01-28-2022, 09:36 AM   #23
garyc
Liked 51 Times in 30 Posts
building my b-body mopar stocker, now under wight, will add wight under rear seat, wight in class guide is less driver??? 170 lbs for driver over scales ??
gary
garyc is offline   Reply With Quote
Old 01-28-2022, 02:32 PM   #24
west coast
Liked 227 Times in 74 Posts
Talking Re: Where is it legal to add ballast?
West Coast do you race a Camaro with a water leak?
No but I was there for it and the woodburn one also
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 02-01-2022, 01:00 AM   #25
bry-war
Liked 2 Times in 2 Posts
I acquired some large 4x8x.125 sheets of lead and I thought it could be converted to race weight. First and not legal thought was to fit it under the entire floor pan under the carpet. It's dead soft but maybe still deadly, especially if you chew on it.
bry-war is offline   Reply With Quote
Old 02-01-2022, 09:30 AM   #26
Rsmith38
Liked 28 Times in 15 Posts
You can fold it into blocks and then bolt it.
Rsmith38 is offline   Reply With Quote
