Thread Tools | Search this Thread | Display Modes |
***Gear Sets***
Strange Aluminum Carrier (Used) ***$950*** *40 Spline Strange Steel Spool (Used) *Low drag Ball Bearing Pinion Support (used) *4.88 Richmond 9310 Pro Gears (Used) *Includes Shipping Container ***Ignition Boxes*** MSD 7530T Ignition box (Used) ***$390*** * Tested good from MSD * OE Harness and cable included ***HEADERS & COLLECTORS*** Dynatech Merge Collectors (Used) ***$175 each*** *2.125 primary, 3.5 outlet. Factory Ceramic coated ***Shocks and Springs*** Koni Electric Shocks ***$1000*** * Used 2010 to 2014 Season * GMM Air Sweeps * Gen 2 MSD Style Control Box * Comes with spring Bearings Eibach 2.5x14.00 200# Springs (Pair) Used ***$50*** Eibach 2.5x8.00 200# Springs (Pair) Used ***$50*** Eibach 2.5x8.00 225# Springs (Pair) Used ***$50*** Eibach 2.5x8.00 300# Springs (Pair) NEW! ***$50*** ***Engine Valve Springs*** PAC-1370L QTY 8 NEW! ***$250*** PAC-1355H QTY 13 NEW! ***$300*** ***Fuel System*** Barry Grant 400 Fuel Pump (Used) ***$125 each*** Barry Grant 2 port regulator (Used) ***$25*** ***TRE Tunnel Ram Dominators (Used) ***$1200*** * Holley 4500 Style * 1.83 Venturi * 2.125 Blades * Billet metering Blocks ***Engine Top End*** *2013 MBE Splayed Valve Cylinder Heads 16 Runs Last Freshened 04/2018 ***$7500*** *These are MBE/DART Casting, cast Heads. No GM Part Number *Xceledyne CRN Titanium Intake Valves *Victory DLC Titanium Exhaust Valves *Setup for PAC 1355H *Jesel Aluminum (solid body) Rocker Arm Set with hardware and Stands *2.0 Pivot Length *1.85 Intake Ratio *1.85 Exhaust Ratio (1.75 Ratio available as Option or in additional for extra $800) *Ball Type Adjuster *Needle Nose Bearings *-10 Vacuum Pump Connection *HRE Intake Manifold, Dual 4500 Top, includes drop-ins, Billet Runners, -12 Vacuum Pump connection, For 8.900 Deck Last edited by 3354 C/AA; 04-08-2022 at 04:20 PM. Reason: 7AL2 is now sold |
Liked 33 Times in 17 Posts
You have a PM.
Liked 14 Times in 1 Post
Pm sent
Liked 49 Times in 10 Posts
you have pm
Liked 61 Times in 22 Posts
I will take the O2 stuff if available.
