Old 02-26-2022, 07:59 PM   #1
3354 C/AA
Default Strange, Racepak, MSD, Cylinder Heads and more
***Gear Sets***
Strange Aluminum Carrier (Used) ***$950***
*40 Spline Strange Steel Spool (Used)
*Low drag Ball Bearing Pinion Support (used)
*4.88 Richmond 9310 Pro Gears (Used)
*Includes Shipping Container
***Ignition Boxes***
MSD 7530T Ignition box (Used) ***$390***
* Tested good from MSD
* OE Harness and cable included
***HEADERS & COLLECTORS***
Dynatech Merge Collectors (Used) ***$175 each***
*2.125 primary, 3.5 outlet. Factory Ceramic coated
***Shocks and Springs***
Koni Electric Shocks ***$1000***
* Used 2010 to 2014 Season
* GMM Air Sweeps
* Gen 2 MSD Style Control Box
* Comes with spring Bearings
***I have electrical harnesses, Air Solenoids, and Digisets available. Ask for price.
Eibach 2.5x14.00 200# Springs (Pair) Used ***$50***
Eibach 2.5x8.00 200# Springs (Pair) Used ***$50***
Eibach 2.5x8.00 225# Springs (Pair) Used ***$50***
Eibach 2.5x8.00 300# Springs (Pair) NEW! ***$50***
***Engine Valve Springs***
PAC-1370L QTY 8 NEW! ***$250***
PAC-1355H QTY 13 NEW! ***$300***
***Fuel System***
Barry Grant 400 Fuel Pump (Used) ***$125 each***
Barry Grant 2 port regulator (Used) ***$25***
***TRE Tunnel Ram Dominators (Used) ***$1100***
* Holley 4500 Style
* 1.83 Venturi
* 2.125 Blades
* Billet metering Blocks
* Buyer Pays Shipping
***Engine Top End***
*2013 MBE Splayed Valve Cylinder Heads 16 Runs Last Freshened 04/2018 ***$7500***
*These are MBE/DART Casting, cast Heads. No GM Part Number
*Xceledyne CRN Titanium Intake Valves
*Victory DLC Titanium Exhaust Valves
*Setup for PAC 1355H
*Jesel Aluminum (solid body) Rocker Arm Set with hardware and Stands
*2.0 Pivot Length
*1.85 Intake Ratio
*1.85 Exhaust Ratio (1.75 Ratio available as Option or in additional for extra $800)
*Ball Type Adjuster
*Needle Nose Bearings
*-10 Vacuum Pump Connection
*HRE Intake Manifold, Dual 4500 Top, includes drop-ins, Billet Runners, -12 Vacuum Pump connection, For 8.900 Deck
3354 C/AA is offline   Reply With Quote
Old 03-01-2022, 05:04 PM   #2
Kdw1403
Liked 68 Times in 22 Posts
Default Re: Strange, Racepak, MSD, Cylinder Heads and more
Interested in the sb2 intake. 901-503-4373.
Kdw1403 is offline   Reply With Quote
Old 03-02-2022, 02:39 PM   #3
RonB
Liked 50 Times in 15 Posts
I'll take the Racepak. PM sent.
RonB is offline   Reply With Quote
Search this Thread:
Advanced Search
