#11 |
James Schaechter 3163 STK |
#12 |
Liked 9 Times in 5 Posts
I haven't tried it. I've heard of it being used in a heads up situation, not sure I'd run it all the time.
#13 |
Liked 333 Times in 180 Posts
Red line or if you don't put a whole lot of laps on a car JD TDH winter blend fluid--- but keep an eye on everything ---stuff works but very thin not for putting it in in March and running it for 200 laps either til November ---
#14 |
I think most if the synthetic stuff is really good so there may not be a lot of difference in them.
That being said, we run redline super lightweight shockproof in the trans and rear end of our 66 Nova E stick car and Redline lightweight shockproof in our SSGT superstock stick car without any issues ever. That stuff seems clingy and super slick at the same time. Tried some stuff that a PS team gave us once. It looked like ATF. 283 four speed stocker 2900 lbs. it literally ate the ring gear in 3 passes…
#15 |
Liked 226 Times in 76 Posts
Anyone have experience with using DLC (Diamond Like Coating) on ring gears? I know that Nascar uses (or had used) that coating for durability and friction reduction. I know, not apples to apples, but just curious.
Andy Friar |
#16 |
Liked 189 Times in 48 Posts
The Red Line Super Lite Shock Proof -
I have had no problems with gear life Sorry for the late reply but it seems to be the consensus here.
Angelo DiTocco '98 Firebird SS/HA '98 Firebird B/SA |
#17 |
Liked 129 Times in 53 Posts
After having some issues with gear life in the past using Red Line shock proof(blue stuff) I started using this brand 12-15 years ago:
https://www.lambcomponents.com/misc-...-oil-1605.html If it robs you of any et I cant say but it solved my ”wear issues” !
Stop global whining |
