Old 03-26-2022, 03:23 PM   #11
Liked 5,150 Times in 1,966 Posts
Default Re: Chevy II front end alignment
Originally Posted by Tom Meyer View Post
Eddie Rezac, search this site for him. He makes a kit for Chevy IIs. My car had been modified by Jack Argnew way back in the day, lots of wild stuff done to control arms. Global west makes a lot of good parts for early Nova front ends. Tom
Pictures of Eddie's kit are about as rare as media coverage of the laptop from hell in 2020. ;-)
Old 03-26-2022, 05:40 PM   #12
prostockpete1
Liked 90 Times in 52 Posts
Thanks Tom ..for passing Eddie's phone # along. ..last time I saw / spoke to Eddie was at a PRI show years ago. ..great guy
prostockpete1 is offline   Reply With Quote
Old 03-26-2022, 05:44 PM   #13
prostockpete1
Tom ..I also had my 65 Chevelle front end worked over at Jack Arnews in Baltimore back in 1979
Old 03-27-2022, 08:52 AM   #14
Dave Casey
Liked 804 Times in 168 Posts
As Mark said, Limit the frontend travel, it get wacky quickly at the top of travel.
Dave Casey 1330 STK
Old 03-27-2022, 04:21 PM   #15
Ed McLawhorn Jr.
Liked 19 Times in 17 Posts
I have 2 Chevy2's and one I installed Eddie's kit. Works great and no problems for drag racing. The other one, I reached out to Pete Zawadzki (sp). and his stuff works too. I'm not sure if he is still messing with Chevy2's? He did sell me a kit, but I believe he prefers car in his shop. I'm in NC and I was able to get his components and he is located up north where it's cold. They can be a mess to drive when the front end gets up.
I had long conversations with Eddie and he said the lower the front end stance is generally the better. He is very knowledgeable with these front ends. Good luck.
Ed
Ed McLawhorn Jr. is offline   Reply With Quote
Old 03-27-2022, 06:13 PM   #16
Frank Castros
Jack Arnew or Eddie Rezak
Old 03-31-2022, 10:16 PM   #17
vette5148
Liked 44 Times in 14 Posts
I have a hunter computerized alignment system. It's an older one but still gives accurate readings. I agree with limiting travel on a Chevy II. I always run the car through the whole suspension travel to check and adjust bump steer. Caster is very important to top end stability. 2 1/2 to 3 1/2 degrees is nice but too much also makes it hard to steer. Camber settings are dependent on how much stuff changes as the suspension goes through it's travel. I watch camber change as I check the bump steer and kind of pick a spot in the middle for a setting. Everything can't be perfect for the whole run but I will raise the front a little to simulate going down the track and set the toe at zero because in or out the tire is still scrubbing. I've been doing this for over 30 years and have had pretty good luck. Just my thoughts. Thanks!
vette5148 is offline   Reply With Quote
Old 04-01-2022, 09:47 AM   #18
Doug Domm
Liked 85 Times in 22 Posts
Are you setting alignment with driver weight in the seat?
Doug Domm is offline   Reply With Quote
Old 04-01-2022, 09:31 PM   #19
vette5148
Yes. Sorry I forgot to mention that. I always put weight in the seat to simulate the driver.
