Old 04-22-2022, 10:41 PM   #1
stocker396
stocker396's Avatar
Liked 58 Times in 16 Posts
Question Gear ratio/ Tire size
Trying to see what the general consensus is on recommended gear ratio would be in conjunction with tire size.
396 / 325 Automatic 3 speed 2.75 low 4:88 or 4:56?
92.5 “ or 94” Hoosier radial?
Would it be the same for 360/340hp (bigger cam) as well?
Wanting to hear about real world tests/results?
Help appreciated. Thanks in advance.
Overkill is Under-rated
stocker396 is offline   Reply With Quote
Old 04-23-2022, 12:04 AM   #2
GTX JOHN
Default Re: Gear ratio/ Tire size
4.56 and either tire size would be my suggestion.
I think the 325 / 396 is not a super high rev combo.
John Irving
741 Stock
741 Super Stock
Old 04-23-2022, 10:28 PM   #3
TommyPettigrew3076
Liked 26 Times in 11 Posts
Find a chassis dyne throw it on there see where the motor is actually make power and torque . Unless you your combo is built identical to others running the same stuff you are just guessing where it wants to be . I would think someone would chime in that runs that combo I know there are a lot of them out there
TommyPettigrew3076 is offline   Reply With Quote
Old 04-26-2022, 11:40 AM   #4
ken robinson
Liked 224 Times in 87 Posts
There's only 100-150 RPM difference between the 92.5 & the 94 .
Old 04-26-2022, 06:01 PM   #5
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Mine likes 4.33 in F weight, 4.56 in G weight. They don’t have a ton of RPM on tap. With the 350hp combo 4.56 would likely be okay in the lighter class, but the cam doesnt seem to increase RPM range by much.
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
