I have installed a new Bullet hydraulic cam and solid lifters in my stocker and broke it in properly.
Now I need to set the valves for racing. What valve lash for valves set cold as opposed to hot? Thanks, Ron |
Liked 974 Times in 310 Posts
Depends whether you have aluminum or iron heads. Best method is set them cold then see what it changes to when hot.
Iron heads on an iron block.
Liked 49 Times in 22 Posts
You can set them really tight, from 3 to 5 thousand's
Steven Barnes Stock 704 N/SA |
#5 | |
Liked 520 Times in 176 Posts
You could consult with Bullet on this since they ground the cam, I'm thinking they would best. I'd also set the lash a couple of thousand's looser on the exhaust side verses the intake side due to the extra heat in that valve over the intake valve. You'll find everything will expand or contract due to temperature difference's. Have a productive day! Respectfully, Henry Kunz 1534 H/SA |
