Liked 130 Times in 20 Posts
Lots of parts for sale-
SOLD-Small block ford Advanced clutches 10" single disc clutch, Fresh and ready to go hasn't been run since being freshened by Hyatt, 1 3/16- 18 spline disc, 164 tooth flywheel, removable 28g counter balance. Total assembly weight 28lbs 11oz $1300 -Small block ford 10" Mcleod Softlok single disc clutch, setup by Hyatt, has runs on it but in great condition, disc still .360 thick, normal wear, 1 3/16-18 spline disc, 164 tooth flywheel, 28g counter balance. Total assembly weight 32lbs $850 -Lakewood bellhousing for small block ford, Jerico pattern, great condition. Includes backing plate, throw-out bearing, Lakewood fork #15525 and is in the Lakewood box. SFI tag is punched April of 2014 $400 -Moroso 20105 6 qt LS oil pan, fits 1955-1987 GM cars (except G body) 5 3/4" deep, cast aluminum, used in my camaro last fall only, like new. $300 -SBC head castings, SOLD 1- set of 3884520 heads $150, 1-set of 3911032 heads $100 -CSR Platinum pro Starter 100P chevy V8 153 or 168 tooth flywheel, has been rebuilt with newer powermaster solenoid, starter gear in great shape. $175 -Mr Gasket 5903 SBC 1955-91 ultra seal header gaskets, I have 4 new sets in the packaging, get all four sets for $100 -Steel driveshafts 3 1/2" diameter- 43 5/8" center of joint to joint, 1350 ends Jerico yoke $125 40 7/8" center of joint to joint, 1350 ends Jerico yoke $125 SOLD-Aeromotive fuel pressure regulator 13204 A1000 Carb bypass regulator used for 3 years on my SS car until I switched to efi $125 -Autometer pro-comp 2 5/8" ultra lite silver 0-1600lb electrical brake pressure gauge pn#4467, gauge was recently removed form my car works perfect, comes with gauge, wiring, sensor and carbon fiber cup mount pn#2151 $100 -2 JAZ plastic race seats with black covers $200 -ARC 3700 overhead pro stock 6 fused switch panel, roll bar mount $125 -Pit pal oil rack #312, 24 quart oil tray 60"x 4 3/8" $50 All items can be picked up, shipped or I can bring to Indy pts meet in a few weeks. Please call, text or email I don't get to class racer messages as often. Can text or email pics of all items listed. (616)437-4958 brad@zaskowskibuilders.com
Brad Zaskowski 3697 STK, SS Last edited by Brad Zaskowski; 05-08-2022 at 03:22 PM. |
