Old 05-19-2022, 07:02 PM   #1
rod
Liked 20 Times in 15 Posts
Default Cragar S/S balance?
I have been told and believe that is hard to spin balance the S/S rims because the area under the cap is not true to the mounting surface. so I have always bubble balanced mine, with a good outcome.
However, there is no one, in this town, with a bubble balancer any more. dont want to have a bummpy ride.
thoughts/ideas
thanks Rod in AZ
rod is offline   Reply With Quote
Old 05-19-2022, 07:22 PM   #2
Default Re: Cragar S/S balance?
Depends on how they jig it up.
Don't use a cone in the back...just a flat cup that rides on the machined drum surface.
Then use a small cone in the center hole. Don't over tighten.
Should run true and balance right up.
Old 05-19-2022, 10:21 PM   #3
GTX JOHN
Up the road a Hour in Boulder is a tire shop that just did
Jon Jr's 4 Cragar SS's last week!
If you get up this way = I will buy you lunch!
John Irving
741 Stock
741 Super Stock
Old 05-20-2022, 02:02 PM   #4
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
I bought a bubble balancer at harbor freight. About $60. Used it many times with success.
chris ok is offline   Reply With Quote
Old 05-21-2022, 10:53 AM   #5
Eman
Liked 133 Times in 76 Posts
Ask around if anyone has the adapter to use the lugs to mount the wheel to the balancer. Like others I bought a bubble balancer from HF.
