Old 05-22-2022, 12:34 PM   #1
Matt S
Liked 20 Times in 12 Posts
Default Wheelie Bars?
What does everyone like for wheelie bars on their leaf spring cars? I haven’t had much luck with a set from Calvert. It seems like as soon as the bars hit it wants to push the back of the car up and unload the rear tire. This is a Camaro on split mono leaves with a Ford 9” rear.
Matt S is offline   Reply With Quote
Old 05-22-2022, 08:05 PM   #2
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
Default Re: Wheelie Bars?
You need a good set of front shocks to control the rate and height of the front end.
Old 05-22-2022, 08:28 PM   #3
Liked 10,966 Times in 2,260 Posts
Question Re: Wheelie Bars?
May want to consider raising the the bars up a little at a time until the 60’ slow down. Just a thought.
Old 05-22-2022, 09:12 PM   #4
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
I like a set with some springs on them to give a little cushion when they hit the surface. Competition Engineering has a decent set that I use on my 1973 Formula with leaf springs.
Old 05-22-2022, 09:29 PM   #5
Matt S
AFCO 3840BNC double adjustable shocks in the front, 3870BG in the rear. Honestly, both are probably still a little too loose on the extension. I do have some adjustment left where I can tighten the extension a little more. It's killing the sidewall in the rear, and the front rises rather quickly. I'm sure this is all part of the problem.
Larry, I'm out of upward adjustment on the bars at about 3.5" between the bottom of the rear wheel and the ground. I've even gone so far as to cut the bars apart and fabricate new attachment points to gain a little more clearance, but I'm maxed out. Seems like a lot of folks set theirs much higher in this type of application.
Old 05-22-2022, 10:15 PM   #6
SStockDart
SStockDart's Avatar
Liked 606 Times in 213 Posts
Move weight forward, a little at a time and firm up the rear shocks.
Old 05-23-2022, 06:16 PM   #7
J&S Racing
Liked 327 Times in 87 Posts
Ken Kier single
Old 05-23-2022, 07:25 PM   #8
Matt S
Originally Posted by J&S Racing View Post
Ken Kier single
Was in contact with the folks at Ken's shop today. Waiting on a call back, and hopefully we can make something happen there. There is a picture or two on their Facebook of the bars installed on a drop-out center section housing that looks like it would work for me. I don't expect any one part to be the miracle cure-all, but if changing the bars would help make an improvement, I'm all for it.
Old 07-11-2022, 09:40 PM   #9
Matt S
Just to put a period on this, I ended up with a set of bars from Ken Keir. These things are a work of art, but more importantly, the customer service was outstanding. Both Ken and Ronnie Johnson patiently answered all the questions I had, and made me feel as if I was their only customer. I would highly recommend to anyone needing these types of products or services.
