#11 |
Liked 19 Times in 9 Posts
Is storing the trailer away from the sun the most important thing? I have been told that the ultraviolet rays from the sun attack the synthetic rubber in tires, but that ozone from our atmosphere is even more damaging.
I use 295 80 22.5 tires on our motor home and have had one blow out which was unforgettable. Since then I've learned, pull them off after six years from date of manufacture, if in the sun belt and seven to eight years if in a northern US climate. Also stay away from Michelins. I had steer tires crack at 25 K miles and five years. Rig was mostly stored in a warehouse. Michelin just said it was a bad break. I've since learned that Michelins are mean't for big rigs that wear them out in a couple of years. Loren |
#12 | |
Liked 1,986 Times in 599 Posts
Mike Pearson 2485 SS |
#13 |
Liked 54 Times in 12 Posts
Yes and I also got away from using trailer tires and when with a truck tire. The tires are going on 3 years with no problem. And as you know I put around 7000-10000 mile a year on them
#14 |
Liked 51 Times in 30 Posts
most tire blowouts are from wrong load range and under inflated, use at least a E rated TRAILER tire, had D rated that came on new hallmark, blow all out within 2 years
#15 |
16 inch are a huge improvement as already stated!
However, many if not most manufacturers do NOT have room forothe taller tires on their standard trailers my son tells me and he builds and sell trailers. Best to order the taller fenders when trailer is built to make sure. There are some 225/15 radial load range F and G tires available in that size if you do not have room for 16 inch. Hercules is one brand that I remember.
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 05-24-2022 at 09:07 PM. |
#16 | |
Liked 805 Times in 341 Posts
I got some of these from Discount Tire for my 24ft enclosed trailer and they seem fine so far. They are noticeably heavier than the other tires I have had in the past. https://www.discounttire.com/buy-tir...year-endurance |
#17 | |
Liked 373 Times in 131 Posts
I cover all of mine on all trailers and vehicles
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#18 |
I try to run LT truck tires on all of my trailers now with 16's.
After I found out that trailer tires are not regulated, I don't want anything to do with ST trailer tires anymore. Plus, I have had too many blowouts with ST tires. The problem is there are maybe just 2 aftermarket companies that I have found that carry 16 inch wheels with a 5 lug, 4.5 inch bolt pattern. Both are 7 inches wide. No one makes a 16 x 6 with the 5 on 4 1/2 b.p. The other option is 16 " wheels from a Ford 5 lug vehicle but those are 7 inchers as well.
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT Last edited by ALMACK; 05-25-2022 at 03:11 PM. |
