Liked 150 Times in 41 Posts
Looking for part # for front yoke on a metric 200 THANKS Jim Whitehead
Liked 755 Times in 213 Posts
This may help you?
https://www.summitracing.com/parts/sum-731000 |
#3 | |
Liked 5,153 Times in 1,967 Posts
internal clips,...or 1350 , as above, 1 ton truck joint.
1350 u-joint. Thanks for the help.
Liked 520 Times in 176 Posts
Good morning to all,
The output shaft diameter and spline count is the same from a TH200 transmission as is a Power Glide and a TH350. As Mark pointed out you will need to know if you have a standard U-Joint (1310) or the larger U-Joint (1350) . I switched my stuff to the 1350 U-Joints, although I never had any problems with the smaller 1310 U-Joints. I switched when they started putting in roller tail shaft bearings in the Power Glides and they didn't make hardened yokes for the 1310 U-Joint style. I hope this helps, have a good day! Respectfully, Henry Kunz 1534 H/SA |
