#41 |
Liked 869 Times in 165 Posts
I think that wouldn’t be a bad idea. As long as the majority of racers in the effected classes were okay with it.
1189 F/SA Defunzalo Racing Enterprises |
#42 |
Liked 2,361 Times in 558 Posts
How is that a good thing? There are lot of fast lower class cars.
Daren Poole-Adams NHRA Stock/SS 2007 |
#43 |
Liked 2,343 Times in 465 Posts
Doug, I'm just trying to figure out a way that the 1970 402/375 Nova now 415 hp doesn't happen to other combo's. Heads up runs in the upper classes in great air can really screw up a combo. Not just in the A and B cars. One run just over the 1.20 mark and now and the Nova's had to add over 100lbs. A lot of weight for one run. I'm waiting for the 350/255 1969 Camaro's to get the hit. Several have danced around it. And that's not with running heads up. There are a lot of them maybe at that time people will get my point. BP
#44 |
Liked 997 Times in 201 Posts
Not a good idea to lower the indexes. Take for example Div. 3 first race Indy in May. Qualifying list shows about 5 cars, me included, at the bottom of the list just barely under the index. Lower the indexes and none of us are under the index. We do not need to chase anymore racers away from participating. Lowering the indexes does not make any sense.
#45 | |
Liked 1,025 Times in 281 Posts
Make the quotas at races larger so you have to qualify to get in, award points for records at races that count towards afhs, and or give points to top qualifiers and you may see the fast cars show what they have at times.
Duane Hoven 1342 SS/GT |
#46 | |
#47 |
Liked 7,854 Times in 1,750 Posts
Wrong! There are a FEW fast lower class cars.
WAY out of proportion to the number of fast higher class cars.
#48 |
Liked 5,145 Times in 1,964 Posts
Actually, there are quite a few fast lower class combinations that are never going to get built.
1, They are perceived to be at a disadvantage in the eliminator 2, They can't be bubble - packed together. Might as well deal with reality here. Carry on.
#49 | |
A quick scan of the 2021 Stock Eliminator data tells a different story. Statistically, the performance of the lower classes are very similar to those in the mid and upper classes. The upper classes are just WAY MORE populated. There are a couple of exceptions in the front wheel drive classes. You know better than I wether that is because those cars are over factored, the indexes are wrong, or the cars are "Dime Rockets".
#50 | |
You're making my point for me, statistically the classes may be similar IF you're only going by the fastest combos in each class BUT "the upper classes are just way more populated" and there are dis-proportionally more fast combos in the higher classes. Just as a science experiment, pick a number. What's "fast"? 8 under? 9 under? I'll spend some time in Nitro Joe's and look into what percentage of combos are fast in what classes and I'm willing to wager that the higher classes are going to come out on top!
