Old 06-05-2022, 03:17 AM   #1
tolaas
Default Fan
Any idea about electric fan for the radiator, shroud or not shroud.
Camaro -67 295 hk 350.
Thank`s
tolaas is offline   Reply With Quote
Old 06-05-2022, 08:02 PM   #2
BillK
Liked 30 Times in 17 Posts
Default Re: Fan
When I had my 67 bracket car I installed an aluminum radiator and electric fan and shroud assembly out of a mid 80's Camaro. I think I had to do some very minor mods to the core support.
Engine was an approx 550hp small block and it cooled it great. With an electric water pump there was no problem making back to back round robin type runs.
Bill Koustenis
BillK is offline   Reply With Quote
Old 06-05-2022, 08:19 PM   #3
Jeff Stout
Liked 708 Times in 285 Posts
Default Re: Fan
Shroud for sure. I had 1 fan just connected to radiator by itself. It work ok. Built aluminum shroud and the cool down time was nearly half as much time sitting in the pit.
Old 06-05-2022, 09:34 PM   #4
Andy Friar
Andy Friar's Avatar
Liked 226 Times in 76 Posts
Default Re: Fan
Fan with a shroud. We put a Dorman brand for a Chevy HHR ON OUR 69 Chevelle sbc bracket car. Stock radiator and it fits perfect. Car just does not get hot. 10.8X car and we can literally loop the track for 3 passes and it doesn’t get. Meziere water pump too. The fan was under $70 delivered and was an easy install too.
Andy Friar
Andy Friar is offline   Reply With Quote
Old 06-06-2022, 08:03 AM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,983 Times in 597 Posts
Default Re: Fan
I dont have a shroud on my radiator and fan. The fan is mounted to the radiator in front of the radiator pushing the air. I typically dont turn the fan on until I am on the return road from the run. No need to run the fan while going down the track. I get the car cool between runs. Temp is usually about 120 degrees at the burn out. 160 after the run.
Mike Pearson 2485 SS
Old 06-06-2022, 03:37 PM   #6
tolaas
Default Re: Fan
Any ideas about brands, and how many cfm do i need? pusher or puller? I had a 16 inch spal fan with shroud for my bracket car and it was newer any problen.
Old 06-08-2022, 09:24 AM   #7
Keith 944
Keith 944's Avatar
Default Re: Fan
A different approach, take a nice day and go through your local boneyard.
There are a lot of newer vehicles with thick aluminum radiators and excellent shroud arrangements I still use the stock Porsche radiator and fan on mine and it keeps the car cool.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 06-08-2022, 05:47 PM   #8
Andy Friar
Andy Friar's Avatar
Default Re: Fan
Damn, you run your car cold! I like to head for the water box at 160F.
Andy Friar
Old 06-08-2022, 06:09 PM   #9
Mike Pearson
Default Re: Fan
Cool engine but I keep the oil warm with a pan heater between rounds.
Old 06-10-2022, 10:47 PM   #10
Andy Friar
Andy Friar's Avatar
Default Re: Fan
Gotcha and makes sense.
Andy Friar
