Old 12-19-2021, 12:43 PM   #1
KRatcliff
Liked 534 Times in 143 Posts
Default LT1 Stocker Motor
Fresh with zero runs LT1 stocker motor. Heads freshened by Gary Hettler. LT1 non filled block. It is my alternate motor that I also have the sequential tune ready for a FAST XFI if that is what you run. The injectors are flowed and staggered for this motor that matches the tune.
New rings, bearings, etc... Originally built by Jeff Warren with a few of my own improvements such as cam grind, solid roller lifters, Manton pushrods, Crane roller rockers, MSD Opti with my water jet cut disc ready for sequential tuning, new plug wires, harmonic balancer, water pump (properly blocked), and everything else you see in the pictures except for the flywheel and clutch (those two are not included). This motor is ready to drop in and it is fast. Well, at least it is fast in my car so I can't speak for anything other than that.
$14,000 and I will deliver or meet you up to 300 miles.
Wrong section. I asked it to be moved.
ID:	61524   Click image for larger version
ID:	61525   Click image for larger version
KRatcliff is offline   Reply With Quote
Old 06-12-2022, 06:11 PM   #2
DCox
Liked 4 Times in 2 Posts
Default Re: LT1 Stocker Motor
What class and car did you run ?
What ET you run
DCox is offline   Reply With Quote
Search this Thread:
Advanced Search
