Old 07-12-2022, 11:13 AM   #1
garyc
Liked 51 Times in 30 Posts
Default mopar valve adjustment
going from non-adjustable rockers to adjustable on my 400 stocker hydraulic cam, using hydraulic until new motor is ready, how do i adjust them? back in the days (small block chevy) ran engine backed off until they clicked then tighten one turn,
put a pushrod thru stamped steel rocker
garyc is offline   Reply With Quote
Old 07-12-2022, 11:53 AM   #2
CMcAllister
Liked 928 Times in 263 Posts
Default Re: mopar valve adjustment
Been awhile, but on hydraulics, we always just went to zero lash. Preload beyond that made it possible for the lifters to "pump up" at high RPM and prevent the valve from fully closing.
Might be a hillbilly way to do it, but we would run the valve adjustment just like a mechanical cam, but would loosen the adjustment a touch until it had clearance, then spin the pushrod with fingers while slowly tightening the adjustment. When the pushrod got snug, stop. Done.
Like I said, been awhile.
Old 07-12-2022, 05:56 PM   #3
65signet
Liked 49 Times in 22 Posts
Turn the adjuster until they are zero lash, and then add 1/2 to 3/4 turn.
Steven Barnes
Stock 704 N/SA
65signet is offline   Reply With Quote
Old 07-13-2022, 07:53 AM   #4
Liked 10,944 Times in 2,259 Posts
You could pull the lifters out with the heads on, shim the lifter to very limited or no travel reinstall and set as solids. That is if you have stock heads.
Old 07-13-2022, 11:04 AM   #5
DanBar
DanBar's Avatar
Liked 12 Times in 6 Posts
First know how much preload works best for your application. Second divide the number of threads per inch of your adjuster into 1. that tells you how much preload per turn off adjuster. as an example if you have a 20 tpi adjuster that's .050" per turn. if you want .012" preload that would be 1/4 turn past zero lash. hope this helps. Dan
DanBar is offline   Reply With Quote
Old 07-13-2022, 01:47 PM   #6
First thing I would ask is what height solid are you using to check the cam lift with?
Old 07-15-2022, 02:41 AM   #7
GTX JOHN
Liked 2,513 Times in 701 Posts
I would do Zero lash plus 1/4 for that set up.
John Irving
741 Stock
741 Super Stock
Old 07-15-2022, 10:42 PM   #8
e vassar
Liked 272 Times in 108 Posts
Years ago 440 with hyd cam in a bracket car. After making a lot of adjustments and a lot of runs, zero lash then 1/4 turn was best.
