Old 06-29-2022, 12:00 PM   #1
Kenney Kelley
Liked 72 Times in 36 Posts
Default Bubble Flare
I recently bought a tube flaring kit for three different types of tubing flares. I know how to do flares on Copper tubing , Double flares on Brake lines but i've never heard the word Bubble Flare used or where they're used. My question is where are they used? and what kind of tubing are they used on?
Thanks Kenney Kelley
Kenney Kelley is offline   Reply With Quote
Old 06-29-2022, 12:41 PM   #2
Mike Jones
Liked 684 Times in 289 Posts
Default Re: Bubble Flare
https://4lifetimelines.com/blogs/kno...r-double-flare
Old 06-29-2022, 02:37 PM   #3
Jim Whitehead
Liked 150 Times in 41 Posts
Bubble flare is very common on todays automobiles, You mostly see it on 3/16 brake line
Jim Whitehead is offline   Reply With Quote
Old 06-30-2022, 08:38 AM   #4
garyc
Liked 51 Times in 30 Posts
basically a double flare and not doing second step
garyc is offline   Reply With Quote
Old 06-30-2022, 12:10 PM   #5
John Dinkel
Liked 263 Times in 68 Posts
Bubble flares are used on brake lines
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 07-01-2022, 11:24 AM   #6
Kenney Kelley
Thanks to everyone who answered my question. I knew the Bubble Flare was different from the others because it required a different flaring cone all together and i had never seen one so that's the reason why I asked. Once again thanks for the response.
Kenney Kelley
Old 07-02-2022, 07:43 AM   #7
Liked 10,769 Times in 2,238 Posts
I’m never to old to learn. Thanks everyone
Old 07-12-2022, 12:11 PM   #8
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
A bit late but a bubble flare is a European standard and not common on US cars. Not sure its road legal in this country. Inverted double flare is stronger. Always match flares and fittings. Here's a chart.
https://www.mpbrakes.com/images/MPB-F200-22.pdf
Dale Shearon
68 Mustang 6394
Old 07-12-2022, 07:06 PM   #9
SSDiv6
Liked 1,586 Times in 583 Posts
A word of caution.
If you are using a bubble flare, make sure the mating components are designed for a bubble flare. The flare has a different shape and will not fit into double flare connections. You cannot connect a bubble flare to a double flare seat.
They have a built in crush surface which means that the flare can not be reused. You also can not connect a bubble flare to a double flare seat.
Old 08-07-2022, 11:19 PM   #10
Todd Boyer
Liked 6 Times in 5 Posts
They've been around for a while on European cars at least. I'm working on an '81 Porsche 911, its brake system has all bubble flares.
