Old 07-16-2022, 04:12 PM   #1
SG7874
Liked 26 Times in 5 Posts
Default TH350 Help Needed!
Hi Class Racer,
Hoping someone can hep with my transmission problem. The short of it is there is no drive shaft RPM distinction between 1st and 2nd gear. 3rd gear is 1:1 but 1st and 2nd are about 1.5:1 each. Gears installed are 1st, 2.52:1, 2nd 1.52:1, 3rd 1:1.
Backstory:
-Purchased a car with the transmission, previous owner had no idea what is was composed of.
-Took it to a S/SS transmission builder to go through it, installed new Coan TH350 TB clean neutral valve body, new front drum, planetary, and new JW bellhousing.
-Installed the transmission and observed the issue mentioned above while in the garage on jack stands.
-Note, prior to this there were additional issues with the new valve body not holding the trans brake, modifications were required. Works well now.
-Took the transmission back to builder he took it a part and could not find anything wrong and has given up trying to find the problem. The shop does not have a transmission dyno.
-Reinstalled the transmission this morning (with only a hope and a prayer) and sure enough it did the same thing.
Troubleshooting I have done:
-Verified the drive shaft RPM ratio is the same at low and high RPMs under load and not under a load in the garage. Note, I still have never been able to make a pass in the car the last two years I have had it!
-Verified via Racepak data there is no drop in RPM when going from 1st to 2nd, there is a drop when going from 2nd to 3rd.
-Verified that the trans brake functions in 1st and verified that the trans brake does not function in 2nd.
-Done the above tests with the shifter installed and having removed the linkage. Verified that there is no issue with the shifter or linkage.
-Verified that reverse has the correct gear ratio, about 2:1.
Note this is for a 2002 SS Firebird.
If there is anyone out there that has any insight or can point me in a direction that might help, would love to hear from you!
Thanks,
-John
SG7874 is offline   Reply With Quote
Old 07-16-2022, 05:36 PM   #2
Mike Jones
Liked 684 Times in 289 Posts
Default Re: TH350 Help Needed!
Not an expert, but if it were mine, to start with....
I would take it down the street, shift it twice, and see what happens.
Good luck
MJ
Old 07-16-2022, 05:39 PM   #3
mike britt
Liked 66 Times in 31 Posts
I can't hear, feel, or see any difference in my car on jackstands but when I drive it down the road it feels fine.
mike britt is offline   Reply With Quote
Old 07-16-2022, 05:46 PM   #4
SG7874
Thanks guys, for the suggestions. I will take it out for a spin on the street tomorrow and see what happens. I am basing this on Racepak data, specifically driveshaft to RPM ratio.
Old 07-16-2022, 05:49 PM   #5
Was the intermediate sprag looked at..not just turned by hand? Does it have the Coan light, small components?
Old 07-16-2022, 05:52 PM   #6
SG7874
Hi Mark, it does not have the lite version. I will have to ask how the intermediate sprag was checked. Thanks for the suggestion!
Old 07-16-2022, 11:04 PM   #7
e vassar
Liked 274 Times in 110 Posts
Not a expert either but I also have a T350 and a fairly loose converter. My tach will drop more on the 2-3 shift than the 1-2 shift.
Old 07-17-2022, 01:14 PM   #8
Eman
Liked 133 Times in 76 Posts
When I had my T-350 it didn't feel like it shifted 1st to 2nd on the lift. As other said road test it.
You mention a new drum, you said front drum. The drum at the front of the transmission is the direct or high gear drum. It's the one without the shaft, the one with the input shaft is the forward clutch drum. The direct drum is the one usually replaced as it is the one that holds the intermediate sprag. The drum with sprag is generally replaced so you get the better 36 elemant sprag. https://www.tsr-racing.com/th350-dru...ent-sprag.html
If this was replaced I'd like to think it's good.
Old 07-17-2022, 04:39 PM   #9
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Mark , Are you thinking the one way clutch on the direct clutch drum is locked up so it starts up in 2nd gear ratio ? There have been some sprag conversions that don't have the end caps and flip the sprag almost instantly .
Old 07-19-2022, 03:34 PM   #10
SG7874
Hi All,
Update time. Took it our for a spin this morning and was able to feel the shift! You can even see it in the data logger. Appreciate everyone's input. Long of it is, just go out and test!
Thanks again.
-John
