Old 07-21-2022, 12:08 AM   #1
Default Clutchless Stocker
I'm thinking of trying to make one of my transaxles into a clutchless deal.
I know it's blatantly against the rules but I see guys on Facebook swinging away and never moving their left leg after launch. I guess it's a look the other way deal like heads and manifolds.
Bobby F sounded shocked when Jim Hughes said he uses the clutch to shift LOL
I know you couldn't do it with the old DNE T 10 style square lugs.You could probably pull it out of one gear but would surely burr up the next one.
I'm not familiar with Jericos.
Could someone post a pic of a gear shifting face and the slider?
Might as well join em' ;-)
Old 07-21-2022, 08:12 AM   #2
TOSTO RACING
TOSTO RACING's Avatar
Liked 662 Times in 187 Posts
Default Re: Clutchless Stocker
The clutchless trans will bounce out of gear when you rock the car in gear. A clutch trans will not come out of gear. I would look into face plating your trans if its possible. Tech will check this and I have been checked before. Just a heads up for you while you are building your clutch trans
5664 GHI/SA
1985 CAMARO RED H/SA
1985 CAMARO BLUE I/SA
TOSTO RACING is offline   Reply With Quote
Old 07-21-2022, 10:06 AM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
We got a tour of Liberties facility and he builds most of the transmissions for Pro Stock . Those transmissions are truly "clutchless" , once the car leaves the starting line there is never a point on the run that torque is not going through the drive shaft . This is a lot different that a "slick shifted" transmission , that drops torque to zero each time the gear shift is pulled . The engineering involved with making a true clutchless transmission is quite impressive !
Old 07-21-2022, 11:37 AM   #4
Yup. About 25 years ago, NHRA would check for clutchless by having you put it in each gear ,and they would rock the car back and forth to see if it would stay in gear.
Checked at Indy..Doug Nash 4+ 1 (minus 1)..No problem.
Anyone been checked by a ghost tech man lately?
Old 07-21-2022, 07:09 PM   #5
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Mark
The clutch assisted sliders and faceplates have different tapered angles so they lock together in my GF5R. The clutchless have a straight angle on the faceplate and the sliders have a ramp with a straight angle, so they do not lock. Just because someone is not using the clutch to shift means nothing. How they have the clutch setup and a trans that is face plated and enough leverage to pull the shifter out of gear, and into the next gear. Or hitting the rev limiter, will unload the trans and allow easy shifting.
A clutchless will not stay in gear unless kept under a slight load. A clutch assist will stay in gear without a load. My trans was clutch assist when my car was a stocker, I never used the clutch to shift going down the track. When I switched to SS I ran the same exact clutch assist trans, until I changed gearing and had it converted to clutchless for $250. The only changes were the clutchless sliders and faceplates. The picture is my trans apart for service last winter. 5th gear is not clutchless all other gears are clutchless and show the ramp. 1st, 3rd and 4th gear sliders are chewed up from the clutch being set too tight, and driver error over several seasons.
Sean Marconette
84 Mustang
5060 SS/N
Old 07-21-2022, 09:03 PM   #6
Pierce Jones
Liked 15 Times in 9 Posts
This season I put a re-geared clutch assisted Liberty in the car that my dad has had for awhile. It picked up over my clutch assisted GForce. The pictures below are a broken faceplate I just changed in the Liberty (first broken Liberty part). In speaking with Brad (great guy) at Liberty this is the stock 7 degree angle. He mentioned that they've made 5, 3, .5 degree faceplates which apparently would be marked as such. I believe that some sort of surface treatment was applied to this faceplate which is why it's shiny.
ID:	63935   Click image for larger version
Pierce Jones
1995 Camaro D/S
#3102
Pierce Jones is offline   Reply With Quote
Old 07-23-2022, 04:00 PM   #7
Yes, I understand the clutchless set-up.
Now, those faceplates only have 7 notches. Assume the slider then has a matching number of engagement dogs?
What holds the plates on? Those pictured don't look like they've been welded.
Picture of slider, anyone?
See, I told you I don't know anything about this modern stuff. ;-)
Old 07-23-2022, 06:50 PM   #8
Frank Castros
Liked 2,746 Times in 969 Posts
Herb McCandless is no longer a contestant.
Old 07-23-2022, 06:52 PM   #9
Frank Castros
But...................He should be!
Old 08-04-2022, 11:32 AM   #10
Nobody wants to talk about this subject?
Understandable ,but c'mon..everybody's doin' it.. ;-)
