Old 07-19-2022, 01:44 PM   #21
sst7250
sst7250's Avatar
Liked 45 Times in 32 Posts
Default Re: Ford Pro Stock
Originally Posted by Greg West View Post
Ford had DRCE style heads or Mopar style heads available. Engine builders could choose to use either one.
I dont think anyone ran anything but the mirror head in the PS Fords. FWIW the new current Mopar stuff is the symmetrical port stuff, seems to workbetter with EFI and 10,500 limit. Before that it was the asymmetrical stuff.
I ran the Mopar 99/06 stuff(which is identical) in a 68 Barracuda.
sst7250 is offline   Reply With Quote
Old 07-19-2022, 03:25 PM   #22
James Hensler
James Hensler's Avatar
Liked 58 Times in 36 Posts
I think you guys are forgetting about Larry Morgan. His **** was fast but he didn’t have the bankroll to test
SS/AH
328X
James Hensler is offline   Reply With Quote
Old 07-19-2022, 04:16 PM   #23
Steve Stasko
Liked 287 Times in 146 Posts
No one forgot about Larry. We're talking about fuel injection and Pro Stock, Larry didn't make that switch on his Ford program. He only ran it carbureted. To date, I believe Charlie Westcott is the only person to run a fuel injected Ford in 500" Pro Stock.
Old 07-23-2022, 01:37 PM   #24
Rick J
Liked 73 Times in 37 Posts
The Ford DRCE style head was never used, casting was too thin to be usable and never fixed.........
Rick J is offline   Reply With Quote
Old 07-23-2022, 11:23 PM   #25
frank johnson
Liked 11 Times in 5 Posts
why should FORD care about P/S all they do is get there BALLS busted in FSS Just like they did in P/S back in the day.
frank johnson is offline   Reply With Quote
Old 07-24-2022, 07:03 AM   #26
tommy d
tommy d's Avatar
Liked 359 Times in 135 Posts
No kidding?
Old 07-24-2022, 02:14 PM   #27
SSDiv6
Originally Posted by Ralph A Powell View Post
Ford wasn’t there is a valve train issue with the Ford!
There were two designs of Ford Pro Stock cylinder heads built; the mirror port head and the sequential wedge head. Darin designed and built the sequential wedge cylinder head for the Ford Pro Stock class platform. The belief by many is that the new cylinder head would have given the Ford engines the power to run against the GM engines.
Darin and Ford submitted the head to Glendora for approval and after having the cylinder head in their possession for some time and sharing it with other teams and cylinder head builders, it was rejected.
Two prominent Pro Stock engine builders that I know also told me that many of the features of Ford's sequential wedge head were incorporated into the current version of GM's Pro Stock cylinder head.
Old 07-24-2022, 10:20 PM   #28
Spyphish
Liked 679 Times in 180 Posts
Been there, done that with same results (except Prostock without a sponsor). Phish
Old 07-25-2022, 08:55 PM   #29
Rose Racing
Rose Racing's Avatar
Liked 227 Times in 74 Posts
I guess if you cant see competitive Fords in pro Stock then pull for the competitive Fords everywhere else in Drag Racing.....
Rose Racing is offline   Reply With Quote
