Old 07-24-2022, 12:38 PM   #11
richard diorio
Liked 15 Times in 5 Posts
Default Re: Engine hone fab question
Originally Posted by jamie2370 View Post
I need someone to hone my 305sbc so I can put in new rings. Motor has like 10 passes on it but rings(total seal) I guess didn't take or hone was wrong? I am in the Middle Ga area. We have a guy local that has a new cnc hone machine but he doesn't do stocker motors but he does do lots of dirt track stuff. Just don't want the wrong hone done.
Brush with 220 grit put old rings back
richard diorio is offline   Reply With Quote
Old 07-26-2022, 02:14 PM   #12
NSSGTO
NSSGTO's Avatar
Liked 24 Times in 17 Posts
Default Re: Engine hone question
Originally Posted by richard diorio View Post
Brush hone with 220 grit use same old rings
Agree, have done this a few times with production blocks. We used to run them in on the dyno then brush hone afterwards and reassemble with same rings.
NSSGTO is offline   Reply With Quote
Old 07-26-2022, 03:12 PM   #13
Rick J
Liked 73 Times in 37 Posts
Rings make the bore round.
Rick J is offline   Reply With Quote
Old 07-26-2022, 05:30 PM   #14
B/S 428
Liked 154 Times in 34 Posts
I use leak down and compression check along with obviously is it smoking? Light weight ring pacs can have a inaccurate reading on leak down..I ultimately make my final decision using compression test. If it has say 200# on all cylinders, I'm not to concerned with leak down numbers..JMO Brian Seaberg 627
B/S 428 is offline   Reply With Quote
Old 07-26-2022, 05:34 PM   #15
Bob F
Liked 16 Times in 11 Posts
After you brush hone do you use the deburring brush?
Bob F is offline   Reply With Quote
Old 07-26-2022, 06:35 PM   #16
bubski
Liked 165 Times in 60 Posts
Bubski's like OMG !! some compression testing looking for excessive oil on plugs !! Glad to see there are sum out there who haven't fallen into the snake oil magic hone job that will instantly pick up their car 5 tenths !! But Bubski knows there's always a sucka looking for that magic that doesn't exist !! Bubski thinking most "hone ,ring issues " are from improper cleaning g of cylinder prior to assembly !!
bubski is offline   Reply With Quote
