Liked 51 Times in 30 Posts
not sure where to post ?
1998 V-10 dully, changed front pads 2-3 times 160,000 miles normal with 10,000lbs towing, had to do rear axle seal this weekend. rear drums 13" shoes look fairly new have never changed since new, , are they not working?? what do I check?? I know fronts wear faster then rears gary |
Guest
Posts: n/a
Most OEM dually brakes will last forever. Make sure to go back with OEM. I have 205k and original rears. Feeling guilty so I’m changing them.
Liked 133 Times in 76 Posts
Brake fluid attracts moisture. 24 yo wheel cylinders belong in the trash would be a good starting point.
OMG I didn't think my truck was 24 years old wow
Liked 29 Times in 8 Posts
Is this a FFFFord V10 dually or a Dodge V10 dually? I don't know squat about a FFFFord but on the late 90s Dodge duallys with rear drum brakes we used to swap the rear wheel cylinders to chevrolet or gmc duallie wheel cylinders because they had a larger diameter piston than the Dodge wheel cylinders. Braking was vastly improved and it was a bolt in swap.
DODGE dana 80, same year GM?? yep look the same, gm 1.18 dodge 1.06 bore
Liked 2 Times in 2 Posts
Didn't most of those have a brake proportioning valve over the rear suspension that compensated for the amount of weight over the axle (due to squat)? Suppose that has failed?
Liked 226 Times in 137 Posts
We had problems with that on GM dualies in past!
