Old 08-27-2022, 01:05 PM   #1
oldschool85
Default Koni Spa1 Drag Shocks Users/ Recommendations
What adjustments are you guys using on these shocks?
How many turns from the softest setting for the front and rear?
oldschool85 is offline   Reply With Quote
Old 08-27-2022, 02:30 PM   #2
Hacksaw
Liked 312 Times in 175 Posts
Default Re: Koni Spa1 Drag Shocks Users/ Recommendations
Rears - 5 sweeps on the rebound and 5 or 6 clicks on the compression.
Old 08-29-2022, 07:18 AM   #3
1347
1347's Avatar
Liked 1,022 Times in 281 Posts
I run the Spa1 rears on my Maverick, and I am an 1/8 of a turn off full tight with the Caltrak. When I ran the fronts. I was full loose.
Duane Hoven
1342 SS/GT
1347 is online now   Reply With Quote
Old 08-29-2022, 08:30 AM   #4
Ralph A Powell
Liked 226 Times in 137 Posts
Is SPA1 Koni Shock?
Old 08-30-2022, 09:02 AM   #5
DanBar
DanBar's Avatar
Liked 12 Times in 6 Posts
I am using single adjustable on front,1 sweep from full loose and double adjust on back, rebound 1 sweep from full tight, compression 4-5 clicks from full loose.
DanBar is offline   Reply With Quote
Old 08-30-2022, 02:25 PM   #6
nhramnl
Liked 358 Times in 83 Posts
I have never gone wrong following Pustelny's advice: Start both fronts and rears in the middle of the range and tune from there according to what the 60-foot times tell you. You'll usually be fairly close on the back (starting in the middle) and you'll probably end up loosening the fronts a bit. In my humble opinion, there is no setting that works for all (or even most) cars. Your car wants its own setup.
Old 08-30-2022, 05:21 PM   #7
CMcAllister
Liked 920 Times in 259 Posts
Very true. I like to use aggressive set ups and use the shock to control the housing or the front end. And I like to try to run the rear shock as tight as I can. Some can use shelf shocks, most I see can benefit from something else.
If you get to dead tight, or one notch from dead tight, and the car wants more, it may be time to step up on the shock or shock valving. I want to run the shock somewhere in the middle, so I have room to adjust either way, and still have it as tight as I want.
SPA1 is an old set up. Things have changed. I've taken SPA1 dampers off, replaced them with custom stuff, or an AFCO Big Gun shock, and made for a very different car. Front and rear.
