Old 09-01-2022, 09:27 PM   #1
THROWER2010
Liked 3 Times in 2 Posts
Default 67 Barracuda front suspension
Looking to free up the front end. Bracket car with 440 aluminum head, powerglide.
Stock upper and lower controls, tie rods, box, etc. It does have the small torsion bars and afco double adjustable shocks. Has max travel now with no stops.
I bought the Hotchkis upper arms with rod ends. These will help the caber.
Plan to purchase
1" longer , low friction upper ball joints.
Hotchkis rod end style tie rods.
Question is what to do about lower ball joints? Only thing I can find is Moog.
Any suggestions on the lower ball joints or any other suggestions to free front end up?
Thank you
God bless
THROWER2010 is offline   Reply With Quote
Old 09-02-2022, 07:47 AM   #2
Frank Castros
Default Re: 67 Barracuda front suspension
Contact Jack Arnew, Baltimore MD
Old 09-02-2022, 09:28 AM   #3
garyc
Liked 51 Times in 30 Posts
new ball joints wont change much, use royal purple grease, lower control arm mount where it goes true k-frame, lube inside and back of lock nut so it pivots, does wonders, on my b-body just a little bit of throttle front end comes right up
garyc is offline   Reply With Quote
Old 09-02-2022, 11:12 AM   #4
Steve Stasko
Liked 292 Times in 147 Posts
Why do you feel the car needs to be looser in the front? What is it doing?
If you're bound and determined that the front end needs loosened up...have the shock valving changed.
Old 09-02-2022, 02:08 PM   #5
Mike Jones
Liked 684 Times in 289 Posts
Frank, can you let the poor guy retire...
Old 09-02-2022, 08:08 PM   #6
Frank Castros
Hopefully Jack still reviews this forum as he once did. Jack retired a few years ago, but that doesn't mean he can't share his legendary knowledge with inquiring minds.
I'll bet he might twist a tie rod for the hell of it.
Old 09-02-2022, 10:45 PM   #7
THROWER2010
If you could help me with a number that would be awsome. thank you
Old 09-02-2022, 10:55 PM   #8
THROWER2010
The car works great most of the time. I have installed custom valve shocks by Jeremy at competive suspensions. i have them full loose at "bad" tracks. I would like the car to pitch rotate better. My thought is if i can get rid of the upper rubber bushings and get the suspension to be "looser", car will work better on bad tracks. then on good tracks like Galot and can tighten extension. It's nose heavy with bbm.
I figured this was the place to ask because of the stocker and super stockers using factory style frontend.
Thank you
Old 09-03-2022, 05:05 PM   #9
Mike Jones
Jack Arnew: 443-987-4543
Old 09-04-2022, 10:06 AM   #10
Liked 11,002 Times in 2,263 Posts
Try getting the car at 50/50 and you might be surprised.
