Old 09-04-2022, 10:52 AM   #1
richie 2
Liked 205 Times in 93 Posts
Default exh gas temp.
howdy...would header tube temp. from a heat gun tell me if im rich or lean? carb/bbc w/unleaded fuel. cant get a plug reading and unable to install a EGT meter. tks
Old 09-04-2022, 02:39 PM   #2
MR DERBY CITY
Liked 8,114 Times in 1,531 Posts
Default Re: exh gas temp.
Might work if your crew man is skinny enough to fit under the hood while you are making a run …..
Old 09-04-2022, 05:37 PM   #3
Jim Caughlin
Liked 805 Times in 245 Posts
Not only that but EGT raises very slowly, the temp you see at the finishline is more like what the engine saw at the 1/8 mile mark. EGT is more to see that all 8 cylinders are equal, Oxygen sensor is the tuning device.
Jim Caughlin is offline   Reply With Quote
Old 09-04-2022, 08:38 PM   #4
B Parker
Liked 2,343 Times in 465 Posts
The best way is to read your plugs. Even if you have to when you get back into your pit area. If far from the end of the track have someone pull you back with a golf cart. If you can't read your plugs after a couple of runs find someone that can. BP
Old 09-04-2022, 09:21 PM   #5
SSDiv6
Jim is correct. By the time you are in the top end and shut down the engine unless you have a data logger, the ambient air will cool down the headers. That's why I prefer an AFR with datalogging.
Old 09-04-2022, 10:16 PM   #6
richie 2
great insight derby tks.. ive read that trying to read a plug using unleaded fuel is near impossiable. they presently show pretty clean, no colour what so ever.
Old 09-05-2022, 10:01 AM   #7
Charles Stewart
Liked 755 Times in 213 Posts
This link will help you...
https://www.dragstuff.com/techarticl...ark-plugs.html
Charles Stewart is offline   Reply With Quote
Old 09-05-2022, 11:57 AM   #8
Stan Weiss
Stan Weiss's Avatar
Liked 734 Times in 385 Posts
Even if you ran it long enough to get a true EGT reading.
Is EGT really a good indicator of A/F ratio?
Stan
Old 09-05-2022, 12:48 PM   #9
SSDiv6
Stan
No.
Had a great discussion with Robin Wright on this subject and his findings based on his tenure with the Ford Factory Off-Road Truck Racing and while at GM with the development of the LS racing and COPO program when I was purchasing a digital dash and data logging system.
After our discussion, we agreed that a wideband AFR system with data logging provides a lot of more useful information for tuning than EGTs do.
Many Pro Stock teams and dyno operators have the Daytona Sensors WEGO system.
https://patterson-elite.com/data-rec...ng-aid-114001/
The display and data logging system I ended up purchasing was from RPM Performance Products with the AFR option.
Old 09-05-2022, 06:59 PM   #10
Jim Caughlin
Stan
No, EGT raises very slowly and not an accurate method of checking A/F. Oxygen sensor is relatively quick and accurate. Millions of cars are driving down the road with their fuel injection being monitored by Oxygen sensors. One negative of Oxygen sensors is they don't live a long life with leaded fuels. Once they go bad, there is no fixing them so a somewhat expensive disposable part on a race fuel engine.
