Old 09-11-2022, 08:43 PM   #11
Ralph A Powell
Liked 226 Times in 137 Posts
Default Re: Impact of water grain and % oxygen
It’s is the system to with the optional Oxygen meter.
Old 09-12-2022, 09:48 AM   #12
Charles Stewart
Liked 755 Times in 213 Posts
Charles,
If you want to learn all about weather correction, get Patrick Hale's book, "Motorsports Standard Atmosphere and Weather Correction Methods".
https://dragracingpro.com/books
The book is considered the best on its subject.
Also, for software, I recommend Performance Trends "Weather Wiz".
Extremely accurate, as long as data inputs are good.
http://performancetrends.com/Weather-Wiz.htm
Thanks for your precious input SSDiv6,
I own a copy of Mr. Hale book and I have read and re-read that book quite a few time.
May be it's time to do it again because I'm mssing something here.
I will also take a close look at the Weather Wiz.
Keep on,
Charles Stewart is offline   Reply With Quote
Old 09-12-2022, 10:16 AM   #13
Charles Stewart
"Typically, we ASSUME a constant percentage of oxygen (20.90%) within that density. The only way to determine the actual percentage of oxygen and therefore the actual amount of oxygen per volume is by specifically measuring the oxygen level independently from the temp, hum and press."
Thanks Mr. Bartoli for your precious input.
That was exactly the purpose of my question. I doubted something was missing in my weather calculation and I was also assuming a constant percentage of oxygen.
keep on coaching us...
Old 09-13-2022, 08:14 AM   #14
Ralph A Powell
When we were monitoring Oxygen at the track we were at the Texas Motorplex on Saturday the wind was blowing from Dallas towards the south on Sunday morning it had changed to coming up from the gulf with same Baro and temp. On the Oxygen meter there was a 1% increase oxygen available and it showed in performance of Fuel Cars and Pro stock.
Old 09-13-2022, 10:15 AM   #15
Charlie Yannetti
Liked 192 Times in 83 Posts
I was going to suggest a decent weather station, but Altronics beat me to it.. I have a Crew Chief Pro system in my trailer, and couldn't believe all the options available for predicting the weather, pertaining to throttle stop and ET predictions.. you will not be dis-satisfied making that move, if you haven't already..
I always looked at density altitude, (DA), while trying to dial, but learned that it is the formula that goes into arriving at the DA that is more important.. that being said, I'll tell you that grains of water and vapor pressure are pretty important.. the higher they go, the slower you go..
Charlie Yannetti is offline   Reply With Quote
Old 09-16-2022, 10:07 AM   #16
Charles Stewart
I must add this previous post from Don Sofranko to this fact:
Re: "Live From" Indy US Nationals The Big GO 2022
Just a curious question after watching the big race from home on NHRA tv
As a past racer at the big go, its always a challenge with the big delays in hours or days between rounds. I was amazed that a bunch, if not all the guys on Monday slowed more than expected, from the early Monday R4 to R5 (3:30 PM) in super stock, and also similar in R5 to R6 Stock. It seems like with all the modern weather stations, and other data that it would have been detectable, to see a slowdown.
Am I wrong or is there another reason for everyone missing the dial by what looks like .03-.04?
Why do the modern weather stations not always tell the picture?
This was from early Monday to the 3:30 afternoon round
Old 09-19-2022, 06:29 AM   #17
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
I’m curious if there were any other apparent changes when this happened. Especially pertaining to Grains/Dew Point.
S/ST 51
S/C 53
Old 09-19-2022, 08:20 AM   #18
Ralph A Powell
No but you could haze coming out of Dallas
