Old 09-14-2022, 11:30 PM   #1
Jeff Stout
Liked 708 Times in 285 Posts
Default PCV oil Seperator in stock?
Can a PCV/Air seperator be installed between valve cover and intake manifold. Wanting to keep oil from contaminating intake.
Old 09-15-2022, 09:15 AM   #2
garyc
Liked 51 Times in 30 Posts
Default Re: PCV oil Seperator in stock?
on my 400 mopar stocker i run the PVC off the intake not carb, so it only does 1 cylinder
garyc is offline   Reply With Quote
Old 09-15-2022, 10:58 AM   #3
Ralph A Powell
Liked 226 Times in 137 Posts
Run it off a carb spacer if you have one.
Old 09-15-2022, 02:00 PM   #4
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
I used to use 1 on my Cleveland. I'm not sure on the legality in Stock but I took it off because there was never any oil in the bowl to drain out. It was on the engine for a few years.
Dave Noll, EF/S ,?/SA 6526
Old 09-15-2022, 02:59 PM   #5
MR DERBY CITY
Liked 8,210 Times in 1,536 Posts
Jeff, I have seen it all in my over 40 years of running stock eliminator. Pcv, master cylinder one way valves, they are all legal.
MR DERBY CITY is online now   Reply With Quote
Old 09-15-2022, 03:10 PM   #6
Jeff Stout
Thank you. I've tried PCV, Sealed caps foam filters in covers, shields under cover all running to base of carb and have a smoking problem when running. Disconnect and smoke goes away. So I wanted to try the separator and hook back up. Hoping to find .3 gain. LOLOLOL
Old 09-15-2022, 06:36 PM   #7
SDT1DYI
Liked 456 Times in 148 Posts
I run a similar PCV system and have difficulty with oil being drawn in the intake manifold. Designed baffles, etc, still get some oil.
I wrote to our Div 6 Tech director asking if I could install a Mororso separator in the line.
I was told, in Stock Class if it did come on the car orginally , " NO"
It would not be legal.
But on the upside, a little oil may help top ring seal. Lol.
If you get a NHRA tech guy to put in writing it's legal to do in Stock, please let us all know..
Steve Teeter Stk/SS 620.
SDT1DYI is offline   Reply With Quote
Old 09-15-2022, 06:46 PM   #8
Billy Nees
Ya know, for years I've run a cheap clear plastic fuel filter in my PCV valve line. It keeps the oil out and when it starts to get some oil puddled in it, I put a new one in.
Billy Nees 1188 STK, SS
Old 09-15-2022, 10:52 PM   #9
I never had that problem but I guess I never went fast enough.
I think, for 200 bucks , I'd dingle hone it and change the rings.
But, I'm pretty sure Jeff got his at the Glendale swap meet ;-)
Old 09-15-2022, 11:59 PM   #10
Jeff Stout
In all honesty it should be re ringed. I feel the blow by may be to much.
