Old 09-14-2022, 11:30 PM   #1
Jeff Stout
Liked 706 Times in 283 Posts
Default PCV oil Seperator in stock?
Can a PCV/Air seperator be installed between valve cover and intake manifold. Wanting to keep oil from contaminating intake.
Old 09-15-2022, 09:15 AM   #2
garyc
Liked 51 Times in 30 Posts
Default Re: PCV oil Seperator in stock?
on my 400 mopar stocker i run the PVC off the intake not carb, so it only does 1 cylinder
garyc is offline   Reply With Quote
Old 09-15-2022, 10:58 AM   #3
Ralph A Powell
Liked 225 Times in 136 Posts
Run it off a carb spacer if you have one.
Old 09-15-2022, 02:00 PM   #4
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
I used to use 1 on my Cleveland. I'm not sure on the legality in Stock but I took it off because there was never any oil in the bowl to drain out. It was on the engine for a few years.
Dave Noll, EF/S ,?/SA 6526
Old 09-15-2022, 02:59 PM   #5
MR DERBY CITY
Liked 8,124 Times in 1,534 Posts
Jeff, I have seen it all in my over 40 years of running stock eliminator. Pcv, master cylinder one way valves, they are all legal.
Old 09-15-2022, 03:10 PM   #6
Jeff Stout
Thank you. I've tried PCV, Sealed caps foam filters in covers, shields under cover all running to base of carb and have a smoking problem when running. Disconnect and smoke goes away. So I wanted to try the separator and hook back up. Hoping to find .3 gain. LOLOLOL
Old 09-15-2022, 06:36 PM   #7
SDT1DYI
Liked 456 Times in 148 Posts
I run a similar PCV system and have difficulty with oil being drawn in the intake manifold. Designed baffles, etc, still get some oil.
I wrote to our Div 6 Tech director asking if I could install a Mororso separator in the line.
I was told, in Stock Class if it did come on the car orginally , " NO"
It would not be legal.
But on the upside, a little oil may help top ring seal. Lol.
If you get a NHRA tech guy to put in writing it's legal to do in Stock, please let us all know..
Steve Teeter Stk/SS 620.
SDT1DYI is offline   Reply With Quote
Old 09-15-2022, 06:46 PM   #8
Billy Nees
Ya know, for years I've run a cheap clear plastic fuel filter in my PCV valve line. It keeps the oil out and when it starts to get some oil puddled in it, I put a new one in.
Billy Nees 1188 STK, SS
Old 09-15-2022, 10:52 PM   #9
Liked 5,136 Times in 1,959 Posts
I never had that problem but I guess I never went fast enough.
I think, for 200 bucks , I'd dingle hone it and change the rings.
But, I'm pretty sure Jeff got his at the Glendale swap meet ;-)
Old 09-15-2022, 11:59 PM   #10
Jeff Stout
In all honesty it should be re ringed. I feel the blow by may be to much.
